GF's Woodturners Finish questions
Henry (Raleigh, NC)
I just bought some to try. I am hoping to find an easy to use gloss finish; I know that I can go to a solvent polyurethane, but prefer a water based or water borne formulation.
I was quite surprised to find a pepto-bismol colour (well close at least), and more importantly a very low viscosity. It seemed like there was very low build on the first coat (all I have tried so far). Is this typical?
For those of you who use it, how do you apply it?
On the lathe or off?
How many coats are typical for a reasonable gloss coating?
Any other pointers I should know in getting the best out of this product.
Thanks.
Henry
Re: GF's Woodturners Finish questions
Jim H
First, let me say that mine is not pink. It is close to cloudy clear, with maybe just a tint of amber. I would be concerned you received a contaminated batch.
I mainly use it on pens and boxes. Usually 10 to 20 supper thin coats applied with a paper towel. First one will raise the grain if you did not wet sand, but easy to knock back. I can put those on in 30 min to an hour. I have a cheap (Salvation Army) hair drier mounted pointing at the lathe. That, with the supper thin coats allows me to put a coat on every 3-5 minutes.
Even though its “dry” wait at least a day or two to buff it, you will get a nice gloss.
George Taylor
George Taylor
I have been using WTF for my wine stoppers recently; I apply a couple coats while still on the lathe and then just set them aside. After they have dried, I buff them with the Beall system and I get a real gloss finish. I haven't really timed the drying time, with me its days/weeks; I would rather be on the lathe & stock pile the turned, finished blanks and not polish/complete them until I have the need.
I hope that helps.
George
Roger Chandler
I have used the Woodturners finish a good bit since it came out. I am on my 3rd can now. It is water based and will build up with additional coats.
What I do is put a base coat of shellac on my turning while on the lathe........usually two coats of shellac and let dry for a few minutes [the shellac pops the grain and serves as a base coat that allows for good adhesion of the WTF]
I then usually sand back the shellac to smooth it and then start applying coats of the Woodturners Finish [WTF] and if I am in a hurry after about two minutes just take a hair dryer and put the fan speed on low and the heat setting on high and apply heat for a few seconds. Then apply more WTF. I use t-shirt material to apply and get super good results.
I also sand back the WTF with synthetic steel wood [fine grit] very lightly before my last coat or two.......I usually apply 4 or 5 coats. This make the final coats really smooth and glossy, and the finish looks better the next day than when coming off the lathe......something about the cure and the leveling.......I get superb results.
Bill Howatt
Are you doing this on all sizes of objects such as bowls?
Bill
Roger Chandler
You have a good point ........when it is hot in the shop and the piece is large, it can dry more quickly than you can coat, thus leaving blotchy areas. The only form I have had an issue with was a large platter and the temp in my shop was about 95 degrees that day.......of course, I had just gotten started using the Woodturners Finish at that time.
Most things I do........boxes, medium and small bowls on a day when temps are not really high have been just fine.
Yesterday, I did a 10" ash vase which did just fine. Of course, the high temp here yesterday was 71 degrees.
