Layers + Vacuum
Hi Darrin,
Did some embedments years ago using epoxy. Couple of things to keep in mind.
1. Primary to any resin is to properly measure and mix the parts. Follow the manufacturer's direction to the letter.; get the proportions wrong and you'll have a lump of soft glop to throw away
2. Epoxy sets up by chemical reaction that generates heat; the more (thicker) the pour, the hotter it gets. Use a slow-setting hardener; fast-set creates more heat. Do not pour sections thicker than 1/2"-3/4" or excess heat will cause deformation during the cure and can actually boil the material which makes a real mess. You can even put the cast in a frig to slow down the reaction.
3. The easiest way to get air bubbles out is to put the mix into a sealable chamber and apply a mild vacuum. The air will foam out of the liquid and you'll get a crystal clear casting. Easy way to do this is with a 5 gal. bucket, a glass or plexi top, and either a vacuum pump (with bleeder valve) or a shop vac. The clear top is so that you can watch the process. You'll need to get a good seal around the rim of the bucket, and then make a fitting to connect the pump or vac. Pulling a light vacuum is usually enough to pull the air out of the mixed epoxy liquid. You can do this twice; once in the mixing bowl, and then again after you pour into the mold (or object). Caution: too much vacuum and the stuff will foam out of its container, making a mess. I usually apply the vacuum, get it to start foaming, release the suction to let the mix resettle, and do this several times until the mix doesn't bubble up.
4. You can put your embedments on one layer, or use more thin layers for greater depth. Pour each layer and watch as it starts to set up. A layer will get to the point where it will support your object, add the object, let it set, then pour the next layer, and so on.
The drawback to layers is that when viewed from the edge, the layers will refract light differently and the effect will be spoiled. There are processes to cast large/thick blocks of Lucite resin, however last time I looked into it the equipment was very expensive (well up in 5 figures).
Hope this give you some starting info.
