THE WOODRAT IS BACK!
Jigs for the lathe.
Jigs for the lathe.
Jigs for the lathe.
David Frame
Which is the best jig book for routers and the lathe?
Re: Jigs for the lathe.
I'm not sure there is one. I thought I saved Harvey Fein's website. He sells some gadgetry for using the router on the lathe.
There is also a guy selling a fluting jig. My friends at Bestwoodtools are going to sell his jig but don't for sure when they will start.
Tell me what you want to do and I'll try to tell you how to do it. I've done an awful lot of router work over the years both on and off the lathe.
David Frame
Thanks for your input John. I'm not looking to but any jigs. I was looking to put a spiral groove into a cane so I can add some inlay. I'm sure it will have mechanical movements to do it. There a lot of books for sale that show someone how to build the jig I'm looking for. I was hoping for something more simple.
David
Re: Jigs for the lathe. *LINK*
I know of 2 sources for building a spiral jig. I will have to do research to find the cable driven one which you build yourself. It is quite accurate and very adjustable but pretty time consuming to build. someone will probably read this and give you his name. He sells a DVD on how to build it. This one is built onto your lathe which probably gives you more accuracy but might be in the way when you need to use it for regular turning work.
The other one is in Bill Hylton's book Router Magic. It is built from wood and bicycle gears and is seperate from your lathe. I think it might have the advantage of being able to build it any size you want.
The other option is to keep your eye on ebay and buy and old Sears Router Crafter. They don't go cheap. I followed them for about 2 or 3 years until I finally bought one for $139 which was the original new price. They were selling for $200 or more. You can build the wooden one mentioned above for less than $100 if you scrounge for the bicycle gears and chains.
http://www.amazon.com/Router-Magic-Fixtures-Unleash-Potential/dp/0762101857/ref=sr_1_1?ie=UTF8&qid=1379588769&sr=8-1&keywords=Bill+Hylton+Router+Magic
Here's the info on the other one *LINK*
Jeff's system works very well and is adjustable for all sorts of spirals from platters and bowls to hollow forms and legs. It is also very adjustable for the size and length of the spirals.
http://www.youtube.com/watch?v=PVCwmmJlN7M
Not a jig but works
Stewart Mortimer's book on creating spirals is great. All the spirals are cut by hand but his methods are quite affective and easy to do if you've done any carving at all. I demo'd his methods about 2 years ago at our club and quite a few quys showed up at the next meeting with spiral pieces.
Stewart will be at the Georgia symposium this weekend and I believe he's teaching an all day class for the Chattahoochee turning club outside Atlanta on the 7th or October if I'm correct.
Eli Avisera designed router mount
Geoff Whaling
Have a look at the Eli Avisera designed router mount / jig.
http://www.lignolathe.com/en/compound_slide/index.htm
