Re: walnut bowl blank - yes remove wax
Henry (Raleigh, NC)
Art - An unequivocal yes to removing the wax. The question is how.
I have no direct experience removing was from a blank I would typically use a face plate and screws into what I hope will be the top of the bowl blank (top of the blank to become top of the bowl). I mount the face plate and blank on the lathe and cut/shape/turn the bottom of the bowl, including a tenon. Once happy with the bottom, I reverse the bowl and use a chuck to hold the tenon. I then touch up any eccentricity in the outside, turn the inside, sand and finish.
To actually answer your question, I would scrape away any wax on gluing surface (don't bother with the other sides if they are waxed). Solvents such as Mineral spirits can be used to remove the residue. Personally even after that I would cut (bandsaw?) or rout about 1/8" or so of material to provide a fresh wood surface.
Once you have a fresh (flat) wood surface (wax free) to glue to, the glue block approach can be used as you would conventionally.
Henry
