Potential deadly piece of wood
I thought I would pass this on. I was cutting out platter blanks this morning from dry wood. This one looked sound until you inspected it extremely close. In fact I would not have found it had I not done my usual test. As I cut off the corners I flex them or tap them on the workbench corner. If one breaks I suspect there could be a problem. On this piece 2 broke almost exactly opposite each other. I inspected the blank very very closely and could barely see the crack on one side. I traced the grain across and could see it on the other side as well. I could not see it on the back or the freshly cut edges. This was a heavy wood and that is about 1/3 or more of the piece that would have flown off once I cut started thinning it out. That would have been very dangerous.
When I cut green wood I typically cut 3 to 6" off the end to get rid of end grain checks. To make sure I make another cut about 3/4" thick and bang this on the corner of my cutting stand. if it breaks I off another 3/4" until I'm sure it's sound. Chainsaw cuts can often mast checks that are still in the log so look very carefully or do the test I do. The very first line of defense for safe turning is starting with sound wood.
I'll be turning ornament finials today so no danger other than possibly a paper cut from the sharp edge of a freshly cut edge or sticking my fingers into the chuck.
Re: Potential deadly piece of wood
Roger Chandler
Nice illustration...........thanks for the pic and the heads up on safety, John!
Re: Good Example
Steve Criscenzo
John
This is a great example of a pre-job safety routine that I tried to explain here last week. The fact that you have a process that you use both when cutting the blank with a chainsaw and prior to mounting it on the lathe demonstrates that you are evaluating hazzards and mitigating them before you ever step up to the lathe.
I too cut the corners off blanks on the bandsaw but never thought to "test" them. Thanks for the tip.
Steve
robo hippy
I do a visual check first, and band saw and chain saw cuts don't really show anything up. Standing out of the line of fire, I turn it down the side and make a finish cut with a gouge and check again. This will show things a bit more clearly. I also do the 'cut a thin piece off and tap it on a table' to expose invisible cracks. Nice point to bring up John.
robo hippy
Very good lesson!
GaryG in MD
Thanks for showing your thought process and testing procedure.
You'll never know it, but you may have just saved someone's life. ...GG
Re: Very good lesson!
Mavdad55
Thanks for the lesson. Makes me want to only turn knarly grain wood to avoide those linear long growth rings
