Un-oiling a bowl
Un-oiling a bowl
Steven Antonucci
Un-oiling a bowl
Steven Antonucci
Oiled a bowl the other day, and forgot wipe the excess away. Got a couple of spots that some minor puddling occurred...and would like to even it out? I wonder if turpentine is the best way to clean it up? It is boiled linseed oil.
(I have turps... but I would go get something else if it was better?)
Steven
Re: Un-oiling a bowl
Rob Wallace
Rob Wallace
You might need to go to an organic solvent to pull off some of the cured or partially cured oil. I am not sure turpentine would be effective on partially cured oil. You could also try something "stronger" such as xylene, naphtha, acetone, or lacquer thinner. You may also need some mild abrasive (steel wool?) to scratch into a cured oil surface while wet with the solvent if the hardened puddles are resistant to solvents alone. I had to do this with Watco (natural) that bled-out of end grain and pooled inside a bowl overnight. I used lacquer thinner and was able to get most of the extra partially-cured Watco out; I then dried the surface of the bowl so it was free of any solvent, and re-applied a thin coat of oil over the entire piece which was almost immediately wiped down. It looked fine after this treatment with no evidence of the puddles below the end grain portions inside the bowl.
Good luck,
Rob
ken ward
I have done that a few time with a danish oil that I mix myself and I just wet sand it with mineral spirits,depending on how bad the puddles are I start with 320 then go finer as needed,it normally doesn't take to long.
Dale Miner
4/0 steel wool wet with mineral spirits has worked for me in situations like yours.
Bill Jacksonville, NC
Naphtha would be a better solvent, but turpentine will work too! Just have rub out little harder on those spots. BLO & pure linseed oil are soluble in turpentine & petroleum distilled solvents & thinners you find at big box and hardware stores.
Is that like being un pregnant
Steel wool first
Jorge
then acetone if needed, the steel wool does quite a good job.
Steven Antonucci
Steel wool is decidedly the answer
steven antonucci
Started with a synthetic pad, and got nowhere fast. 0000 steel wool with some mineral oil really helped even it out. It isn't perfect, but it is as good as it needs to be to hold a salad.
Thanks
Steve
P.S. Mineral Spirits, not Turpentine...
