Any hints on turning a square platter?
Henry (Raleigh, NC)
I just tried a square plate - about 6" on a side, with a glue block on the back.
Two things I noticed most:
1. Layout is critical because unless the glue block is perfectly centered the corners of the plate are different thicknesses - and that is quire noticeable. I did NOT glue on the block, turn the tenon on the glue block, and then reverse it; I simply glued on a block that already had a tenon inside concentric circles I had laid out. How do you or would you center the square?
2. Tear out (chip out?) on the corners is difficult to prevent. Is faster speed helpful? Lighter cuts obviously would be helpful. Any other suggestions?
Thanks
Henry
Re: Any hints on turning a square platter?
Henry, several years ago a member ....
JamieDonaldson
..of my Lousiville club posted a series of 4 videos on YouTube of me doing a square turning demo. His name on the series is Rex Guinn, and a search of "square turning" should take you to the archive. It's not complete, but I cover most of the process I use. I can't be too critical of his handheld camera because I was unaware of his "project," but I'm thankful that he tried. ;)
Part of my mirror turning demo is starting with a square. It's a good learning technique because the piece is going to end up round meaning you eventually turn off the square corners so it doesn't matter how they look.
I do this often to practice my cutting technique. What I find improves the cut the most is being light on the bevel, and not forcing the cut. Angle of cut is also important as well as the sharpness angle and of course the edge must be sharp.
What I learn. When you cut try to cut down hill with the grain if possible. Of course if the square edge is flat you can't do that. Listen to the noise. A loud noise as it gets to the corners means your pushing on the bevel too hard. I heard a great description recently. Pretend there is something fragile between the bevel and wood and try not to crush it.
Slow down your cut, don't force it. Sometimes speeding up the rpm's helps but only if you already have the skills to not push the cut faster than it needs to cut the wood. This is a feel sort of thing and just takes practice. Relax your grip and lighten up on the tool and just let it cu.
Depending on how the grain runs you may find cutting in the opposite direction might help. I will sometimes change to a gouge with a sharper angle to the tip. I will assume you already have a sharp edge.
Many many years ago I asked Charles Alvis (former AAW president) how to turn square platters. His advice was simple. Practice practice practice.
Re: Thanks Jamie, John
Henry (Raleigh, NC)
I will definitely try lighter cuts. I guess I was guilty of hogging it off quickly for general wood removal. and then not being able to recover.
Your video was helpful as well, Jamie. Good reminders.
Henry
Re: Henry, several years ago a member ....
Geoff Whaling
The link is https://www.youtube.com/watch?v=BRgndozF4nQ
Chip in Plano
Couple of my tips
1) i put blue tape on my rest to mark the edge of the square....i like my knuckles. The tape does not interfere with toolwork
2) i don't worry too much about squareness since i can sand it back square enough.
3) chip out happens. light cuts help i have painted CA on the edges most prone to chip out but cut shellac works too. After i have done the primary shaping cuts with a gouge, I switch to pushing shear cut and listen to the noise and watch the blue tape when the cut should start. Jimmy Clewes showed me this cut which scared the crud out of me at first. I do use a pulling shear cut but very lightly because this cut will cause tear out too. #2 sanding is a fallback for some chip out too.
4) power sanding the wings on the lathe is a poor idea. I get a better result hand sanding with the grain
5) If you get too much flexing on the wings, you will feel it at the transition from wings to solid wood. Go back to light cuts to improve the transition; otherwise, you will have fun sanding
That's most of what i know
Joe Flemng
Something I find unattractive about "square" turnings is when the thickness of the wings is inconsistent. When this happens, it transmits to the square edge and looks less well-done to me. It is the very first thing that catches my eye on a squar-edged piece. Stuart Batty always makes a point of maintaining the thickness consistently through the square section so that the edge is even-thecknessed (is that a word?).
Joe fleming - San Diego
