Help with tear out
Help with tear out
terry gearhart
Help with tear out
terry gearhart
Hi folks, so I had a huge chunk of "green" cheery given to me by our towns Arborist, it had to be 2 ft wide x 3.5 ft long and 4" thick. I cut it down to make a bowl for him. I keep getting tear out and not sure what I am doing wrong...the bowl is now pretty thin, thinner than I would like....Please see the attached photo's and please give me some advise....thank you
Re: Help with tear out
we need more info. What tools are you using and how are you using them. The tearout near the rim appears to be a catch which suggests a bowl gouge held in the wrong orientation. The other tearout could be punky wood.
First and foremost use a freshly sharpened tool. If your using a scraper (carbide or otherwise) you will have more trouble controlling the tearout. A freshly sharpened tool and proper feed rate along with the proper cutting orientation will usually take care of most tearout.
Dick Hines
Dick Hines
The knot with the grain going every which way could be some of the trouble.
robo hippy
In the second picture, the tear out is from very punky wood. It is just too soft to cut cleanly. If you catch it before you turn, then you can reinforce it with CA glue, oil finish, Minwax Wood hardener or a couple of other things. In some cases, just getting the wood wet with water or even finish, then taking very light cuts will do the job. It looks too deep to clean up with just sanding and no filling in with sawdust and CA glue, or epoxy and saw dust. Having sharp tools, of course, and I always use a freshly sharpened tool for the finish cuts. High shear angle is important as well. The tear out near the rim looks like low shear angle and/or dull tool. Never use a scraper flat on the tool rest any where near the rim on a bowl that has been hollowed out.
robo hippy
Steven Antonucci
Your bowl is probably vibrating too
steven antonucci
with a knot and some softer wood, odds are that your bowl "flutters" even when you don't have a tool on it. That flutter will get worse if you don't float the bevel. Short answer is that it's really hard, but you already know that.
If it was my bowl, I'd consider trying to remove the tear out with a gooseneck scraper and the bowl in my lap (not on the lathe).
Steve
terry gearhart
terry gearhart
Thank every one for there input......
This is the 3rd bowl I've attempted
it certainly is a learning curve
Brad Vietje
Red Rot
Brad Vietje
Dead wood in Cherry species is often called "Red Rot", and shows up as darker patches. Like Robo says, it's pretty punky stuff, so without a hardening fluid of some sort, like shellac, CA, Minwax wood hardener or similar, your chances of getting clean cuts are poor. If there's more wood without the red rot, you'll have much better luck. The curly crotch figure can also be a little difficult, but that's a whole 'nuther issue, needing super-sharp tools and very light cuts. Also can help to lubricate with wax and use a sharp shear scraper -- Reed can teach you all about it!
Good luck & safe spinning,
Brad Vietje
Newbury, VT
Nick Todd
Have you tried shear scraping and changing up the speed?
terry gearhart
terry gearhart
I have not tried shearing or scraping.....
I thought I would give it a rest and then get back to it
That you all for your knowledge
and support
