A re-newed Longworth chuck *LINK*
Henry (Raleigh, NC)
I just posted this on the main message board, but then realized that it was primarily a turning topic.
After a few catches and bowl dismounts (sounds like gymnastics doesn't it?) from my first shop-made Longworth chuck, I decided I could no longer live with the imperfections (not mine of course - the imperfections are in the chuck that I made!)! I loosely followed Garrett Lambert's advice (link below) - but note the term loosely. I clearly failed to heed admonitions about centering the two plates.
I figured that concentricity between the two base and top plate was the biggest issue, as the mounted pieces were never quite centered. This also meant that re-sizing the chuck for a new piece was difficult because the "buttons" were not moving in the same arcs and they jammed.
I removed the top plate and re-matched it with the base plate, using a few screws to attach them. I tried re-drilling the presumed 'center' hole, but of course the new one was a partial overlap with the old hole and the bits kept straying into the existing slightly off-center hole. I quickly tired of this and simply turned (on the lathe) a mortise about 1.25" diameter through the top plate and into the base plate. Next I turned a tenon on a scrap block to fit into the mortise. I detached the top plate, reversed it for use, and glued the center block into the mortise. When dry, I turned the scrap block down to a manageable size and depth, and re-installed the buttons.
This provided a re-newed Longworth chuck with much improved concentricity and buttons that move in concert with each other to re-size the chuck.
Of course this modification makes the assembly a glued up piece - I can no longer dis-assemble the two plates. But it work better!
Henry
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=turning&file=articles_485.shtml
