Yet ANOTHER Safety Issue ;~)
Brad Vietje
Brad Vietje
Well, well,
We've had some spirited discussions of safety issues, face shields, helmets, and even helmuts (...as in Newton?) I know spirits have been a little high during a few of these exchanges, so I figured a little levity might be in order.
Taking safety to a whole 'nuther level, my slightly tounge-in-cheek safety issue has to do with using razor-sharp tools when shear cutting -- while shaving!
All kidding aside, I seem to have become addicted to extremely smooth cuts, (I just hate sanding, BTW), and I have found myself shear-cutting the whiskers on my FACE! Does anyone else do this -- shave at a 45-degree angle to get a smoother cut??? (Just in case you wondered, I never, ever, sand my face, though 8) )
About 6 months ago I actually sliced the corner of my nose while shaving, and that's when it dawned on me what I was doing -- unconsciously up to that point. Now I am quite conscious of it, but I still find myself doing it -- especially when trying to get a few more shaves out of a razor that probably ought to be replaced. (SEE -- sharp tools really can prevent injuries!)
...then there are all the fancy razor designs.... from a straight razor (well before my time!) to a "safety razor" (safe ????), then 2 blades, then 3, then 4, and now up to 5 -- count 'em five -- blades to cut hair from our bodies! Holy smokes -- pretty soon we'll have get a running start and throw our bodies at a whole WALL of 1000's of blades for the ultimate close shave -- or a julienne face!
I stayed in a hotel about 3 years ago that was giving out samples of a 3-blade razor with a little vibrator in the handle that was supposed to move the blades back-n-forth as it cut... Not sure it worked any better than the non-vibrational kind, but is this really necessary? Maybe the little vibrating handle has other uses that I haven't thought of (?)
I'll know I'm a lost cause when I start shaving with my carefully-honed and stropped skew chisels, but for now I think I'm OK :b Sure hope you are, too!
I hope you all have a very safe and satisfying weekend -- and be careful when "shear-shaving"! ;)
Safe spinning,
Brad Vietje
Newbury, VT
Re: Yet ANOTHER Safety Issue ;~)
Mike Stafford
Mike Stafford
Brad, this warning is particularly true when you are under the influence of drugs that might impair your normal clotting function.
If I nicked myself right now I might have to use a tourniquet around my neck.
That doesn't sound like a good idea does it?
mjonesrdg
Brad,
Just let them whiskers grow! Much safer and cheaper too. I read recently that "Duck Dynasty" was the most watched cable TV program 2 weeks running, and the "stars" of that show haven't shaved in years!
Thanks for the levity! and....
safe spinning back to you!
Dale Jablonski
Dale Jablonski
Not to mention the hazards associated with the application of certain types of "finishes" i.e. Hai Karate
R Payne
If you don't shave then you have to spend a lot more to get a respirator that will filter the air you breath when working. That is the reason I shave. A straight razor is the cheapest shave.
And on that note, a sharp straight razor is the best shave you'll ever get, a dull straight razor is the worst shave you'll ever get.
Get a norelco
Steven Antonucci
not worse than a single bladed hotel freebie
Steven Antonucci
Forgot my razor travelling once...once.
S
Betty Scarpino
Betty Scarpino
Try shaving your legs ... safely ...... : )
Mike Stafford
Not a problem for me....
Mike Stafford
I spent so much time taped up when I played sports that I have very little hair left on my legs. Having it jerked out by the roots is not a method of depilation I recommend although I understand women subject themselves to this torture in preparation for donning summer fashions.
Nevertheless most of my legs are hairless, not shapely, but hairless as a Sphynx cat. And, no, you cannot look at my legs.
Re: Not a problem for me....
Joe Herrmann
Mike's right--I've seen his legs and I wanted to poke out my eyes. Unfortunately, once seen is never forgotten!!
Steven Antonucci
btdt... bicycle racing standard fair
Steven Antonucci
Cut myself a dozen times.
S
Rob Wallace
Re: btdt... bicycle racing standard fair
Rob Wallace
Brazilian/Bikini too?
Steven Antonucci
Supposed to heal faster
steven antonucci
Road racers shave their legs because it was reported that you would heal faster and with less infection if you had no hair and got a "road rash".
If you had a road rash in your bikini area, I am not sure shaving would be that beneficial?
S
I have done this...
Does anyone else do this -- shave at a 45-degree angle to get a smoother cut??? (Just in case you wondered, I never, ever, sand my face, though.)
Any time you skew an edge relative to the direction of travel, it lowers the effective cutting angle. This pertains to shaving, too, but I think it defeats the built-in safety bumpers (or depth limiters or whatever) of a typical razor, so it's easier to slice yourself.
[rant]
My biggest gripe with razors ( I use a Gillette Fusion model, with the 5 blades) is the profit margin these manufacturers (P&G in this case) have on replacement blades. And, to add insult to injury, I have a strong hunch that they have lowered the Rockwell hardness of the blades over the years so that they wear out sooner. I used to get a couple dozen decent shaves on a blade and now it's half that number, and the price keeps going up to boot.
The only thing more maddening is the replacement ink cartridge racket that HP and others force on unwitting customers. We have one printer that not only tells you that your cartridges are almost empty (gotta question that), but also that they are "expired," i.e., out of date. I guess they want you to throw out your half-full cartridges and run to the store for new ones, at $45 a pop or whatever. I'd love to know the margins on those items, too.
[/rant]
Thanks for the yuks, Brad, and the chance to air out a couple gripes. :)
John Lawson
Re: I have done this...
John Lawson
That explains it! I have had a full beard since 1977. I only shave the edges so I don't look homeless, and replacement blades lasted months. I bought a new pack of blades, and they barely last six weeks. I was ready to blame the increased stiffness of all the white hairs, but I think you may be right about the hardness.
Keith Tompkins
Keith Tompkins
I agree Ellis...the blades only last a few shaves. But then, maybe it's my Neandethal roots.... :(
R Payne
My blade has lasted 15+ years. Of course it's a straight razor. Haven't spend a dime on cartridges in probably 12 years. Definitely saved enough to recoup the costs of razor, strop and stone needed to switch as well as the brush and cup which allows me to use bar soap (some brands are better than others) for the lather. All I spend on shaving these days is time.
bill Crommett
Ellis : Your complaint about the Rockwell hardness of the blades remind me of the time I was goose hunting and shot a goose that had a neck band and a leg band, and was obviously old. And that is when I learned that "old" and "tough" go together, and that bird was so tough we couldn't eat it. Question: could this partially refute your suggestion that the company is reducing the Rockwell on purpose ?
I'm with you brother.
Keith Newton
Only shave around the edges, and not that regularly. Bought a set of clippers to knock it down first helps with the clogging.
As for the HP ink. I have switched to Cartridge World ink. there is a store here that will refill, at about half the price, but the cartridges will be fuller, and outlast the off the shelf stuff.
A few months ago, I went in with a photo which ran out half way across, just to get their opinion. When they saw my shot, not only did they give me good advice, and help me with the ink for my printer. They had a better printer than mine that someone had given them when they bought a much better one. They just gave it to me, with new ink in it, saying they just couldn't stand to toss it, hoping to find a new home for someone deserving of it. It is older than mine, but there are problems with the new ones which were not there with these older ones. It does do a great job, and the price of ink is so much lower, I'm a lot happier now.
