ADVERTISE HERE - FREE TRIAL
Grinding Wheels -- Line of Fire
Ric Taylor
Ric Taylor
I have read with great interest the recent postings regarding accidents and the line of fire surrounding wood on the lathe. Many good points have been made and the danger certainly deserves all the respect we can give it.
I haven't seen anyone mention grinding wheels. They are dangerous also and they also have a line of fire.
I am a retired Air Force pilot. For part of my career I flew in Air Rescue. Among the many rescue missions that I flew there were two that happened because of grinding wheels ... on ships ... far out at sea. One was 500 miles out and the other was 800 miles out.
In both cases, crewmen were standing in the line of fire of grinding wheels that exploded. In one case a chunk of the wheel was imbedded in the the crewman's forehead and the other had it imbedded in his chest.
My impression is that many turners take their grinding wheels lightly. I know from direct experience that they are very dangerous. I stand off to the side while they are spinning up, and when sharpening I try to stay off the the side as much as I can. The wheel covers are important, they were designed for a reason, to help contain any shrapnel that may occur if a wheel flies apart. I keep the covers on my wheels, even on my CBN wheel.
This is especially important with new wheels which may contain hidden cracks. But something can stress or bump up against an older wheel, again causing hidden cracks.
Be as safe as you possible can.
Ric
Re: Grinding Wheels -- Line of Fire
John Stegall
Good call Ric. I had one explode on me but I was not in the line of fire, I heard it making a strange sound and knew what was going to happen. I reached for the power cord but it blew before I got it unplugged. It made some large dents in the metal shelf behind where I would have been standing. Being lucky can really help sometimes. The safety shield only served to "aim" it.
Steven Antonucci
I own a Tormek, wouldn't know?
Another plus for CBN wheels.
Ray - Middletown, IN
I was taught to always ring a new wheel before mounting it. Again if something ever bumped into it. If it sounds suspicious dump it.
Ray
Ring Test
Dale Gillaspy
Most "consumers" don't know of the ring test. It is an OSHA requirement that ring tests be performed on all composite abrasive/cutting wheels before they are used, and most manufacturer's provide literature on how to do it, but not many people bother reading the owners manual with a grinding wheel.
Ring test video *LINK*
Doc Green
I had never heard of the ring test and had no idea what it was. Here's the first youtube video I came across to check it out. Pretty good!
This is worth knowing ... and doing when you get a new wheel.
~Doc
Ring Test Video
Re: Ring test video
John lucas
Jeez. I thought a ring test was holding your diamond ring up to the wheel to true up the surface. That is why you wear one isnt it?
Ring Test Elsewhere
Bill Howatt
My wife uses the same technique when she is buying china, glass etc at various antique and junk (my word) sales. She very lightly holds the object and taps it with her fingernail.
You probably can tell the different sound a cracked bowl makes while turning and I don't mean a click-click-click sound - it just sounds dull. You can also tap it with your nail and will hear a duller sound if there is a crack. This isn't as obvious as with a hard object like a grinding wheel or china.
Bill
Re: Ring test video
Only rich retirees use their diamond rings, us commoners have to use the industrial kind. :)
Ray
Never had one explode except for a
small 2" wheel on the internal grinder. Even though we we out of the "line of fire" the wheel pieces went straight up and shattered several florescent bulbs. We got a scary shower of glass shards, wonder one of us didn't get cut. (Pre OSHA lights, no guards).
Ray
