So I bought the Beal Buffing system, the 3 wheel buff system and the 3 inch puff balls. I like the results. But I see some spots that I did not notice, could be sanded a little more. Is sanding good enough to remove the wax or do I have to do something else before I put "salad dressing finish" back on the bowl and then buff the bowl again. How can I remove the wax.
Just thought I would keep adding to the list of solvents. Nothing like soaking the wood in toxic liquids before adding "salad dressing finish"! By the way, what's a "salad dressing finish"? Vinegar and oil?
just to add another. I actually have looked this up more than once, and the best solvent for waxes is toluene. However, as Dick said, these are not really friendly to organic life. The good thing about both naptha and toluene is they will evaporate really quickly, but you have to be careful about breathing those fumes and they have the potential for the vapors igniting. Using them sparingly outside is best. I never had great luck with mineral spirits with wax (but Mike seems to have had good luck with it), but then I usually use either microcrystalline wax or a canuba blend and the minteral spirits may do just fine for the Beall products.
Ok it was Salad Bowl Finish not Salad dressing. Late at night brain not working.
Dan
Product Information:
General Finishes' Salad Bowl Finish is non-toxic and food safe when dry. It works well for wooden bowls, plates, cutting boards, eating utensils and other wood surfaces that come in contact with food. It is also highly resistant to water and food stains. Salad Bowl Finish is applied with a clean soft cloth.
One estimated LD50* for human ingestion is 1.159 g/kg. For comparison, that's 5 to 10 times the toxicity of ethanol, even if you don't count ethanol's interactions with automobiles and firearms.
While acetone is much safer than the other solvents discussed on this thread, it is still toxic. You would not want to drink it, or swim in it.
*The LD50 is the dose which is lethal to 50% of those to whom it is administered.
Back in college, when I took Organic Chemistry, we rinsed all the glassware with acetone to drive off the water from washing, or from the air. There were squirt bottles of the stuff on every lab bench and at every sink. The TA's and older grad students at the time remembered doing the same thing with benzene back when they were in school. Nowadays, undergraduate students need to request permission of the TA's to even use acetone. Hopefully our knowledge evolves with the passage of time.
Later, when I was managing a brain research lab at the UVM medical school, we used a number of benzene compounds for electron microscopy and tissue staining, all of which were potent carcinogens. I posted a sign for all the grad students, technicians, and other researchers to see: "Use Extreme Caution! The only good BENZ is a Mercedes.", which I believe to be true to this day.
Toluene, BTW, is a mighty nasty solvent, and all the solvents mentioned in this thread will raise hell with your liver. The particular danger with Acetone is that it passes right through the fats and oils in your skin, enters the bloodstream, and ends up killing your liver cells. It can also penetrate many kinds of "rubber" gloves -- you might need heavy-duty nitrile gloves to keep it out of your skin. I believe it is now considered a carcinogen as well.
The other problem with toluene is its density. Its vapors like to settle and spread out on the floor, where they are very effective at suffocating snoozing bench dogs and shop cats. Coupled with its very low LEL (lower explosion limit), it is known for setting whole shops on fire starting at floor level, if it encounters a spark (for example, when your compressor kicks in).
At this point I was considering making a comparison (tongue-in-cheek, of course) among a fine Scotch, acetone, and tequila, but I don't want to accidentally encourage anyone to try an acetone cocktail. As far as tequila is concerned, I don't drink it either, because I have a severe sensitivity to the maguey plant they make it from. You have to seriously question a lot of the numbers you find in MSDSs on the internet. Some of them tell me the Scotch should have killed me many years ago. Others properly indicate that there are a lot of chemicals we use in the shop that are a lot more dangerous than acetone, and I should be much more consistent in breaking out the nitrile gloves when I use them.
