Line of Fire question from below:
Steven Antonucci
steven antonucci
Stuart Johnson asked:
If the shaving are hitting you in the chest or face shield doesn't that mean you are in the lof?
In this video, there are a handful of VERY important things for new turners to take away. If you look on YouTube, there are a number of videos where you will see the turner roughing to round with a roughing gouge from the side of the blank. The original reason that I shot the video was to explain that you need to rough from the face grain, and that a bowl gouge was the right tool to use.
Some of the unconscious things that I do (that I am now consciously explaining) are as follows:
You will notice that the tool rest is set at 45 degrees to the work so that the tool crosses it perpendicular. This gives the best support for the tool. In addition, the way that I cut (with the handle low) was something I originally picked up from Terry Daniel. Having the handle low allows me to anchor the tool against my hip and use my body to make the cut (instead of my arms), but more importantly- it directs the shaving downward instead of upward towards my face! To answer Stuart's original question, with my left hand in place, over top of the tool, all of the shaving are blocked by my hand and they do not become airborne if I am pull cutting (as seen in this video- I am standing between the tool and the work). If I am push cutting (i.e. tool is between me and the work piece), the shaving are thrown out in front of me. It was not possible for me to shoot this video push cutting, because I am highly right hand dominant.
My left hand is not really involved when I turn, other than to deflect chips and keep the tool down. Whether people agree about the safety of this or not, most people don't realize that it can be done... but it involves truly understanding the forces at work and where they want the tool, shavings, and work piece to go.
Two other subtle points to cover. First, as far as the Line of Fire goes, I am standing behind it, as it is perpendicular to the bed of the lathe for the length of the blank. It is not an accident that the tool rest is at 45 degrees across the LOF, as I want to have something between me and the work piece to block and deflect an accidental dismount. More importantly, having other things to hit lowers the amount of energy in the flying wood. Every collision before me takes energy and redirects the blank away from me, and that is what we're hoping for. Low energy accidents (if any at all).
Last thing I'll point out is that you'll notice that I start on the outside and cutting the corner off. Can't cut the middle until I cut the outside? More importantly, if you have ever tried roughing an out of round blank from the middle, odds are you stop before you get to the end, and now you start building those pointy valley on the outer edge. When you cut through them, the usually come off in big chunks that go ricocheting around the shop. The way that I rough, they never form, so I never have to duck them.
Consciously describing the unconscious behavior...
S
Re: Line of Fire question from below:
Stuart Johnson
Thanks Steve. Watching the shavings, cutting edge and flute I see what you mean.
Nothing to disagree with there Steve,
Keith Newton
But for LOF, a simple enough rule, would be that if you sprayed water on it, and any water sprayed you or anyone behind the lathe, that should be no-man's-land.
Steven Antonucci
good rule of thumb
Steven Antonucci
I am always amazed when someone will stand at the back side of the lathe directly in the LOF. I don't think most new turners think of it in three dimensions.
I'll add that to my description.
Steve
