Grinding wheels??
Grinding wheels??
Jesper, Denmark
Grinding wheels??
Jesper, Denmark
I have a Baldor slow speed 8" grinder, which is even running at slower than the original 1800 rpm, as it is on 50 Hertz power. It is equipped with a blue and a white wheel, which was the "in" thing at the time they were installed some 15 yeas ago. Both are something like 100 grit, and the set-up is that one is used with a modified tool rest for scrapers and the like and the other with a Oneway jig for sharpening gouges.
They are now worn down to less than 7", so need replacement. The grinder is only used to sharpen lathe tools.
Re: Grinding wheels??
David Walser
Jasper,
Are you asking for recommendations? I like the new CBN wheels. In your situation, I'd be tempted to stay with an 80 - 100 grit ceramic wheel (like a blue Norton) for shaping new tools and get a 200 grit CBN wheel for sharpening tools. Once the jigs is set properly, the CBN will get a tool very sharp while removing very little metal. The diameter of the wheel never changes, so the size of the hollow grind and shape of the bevel will be very consistent from one sharpening to the next.
Darryl
Put the 180 grit CBN wheel from David Ellsworth on your grinder. You will never need to replace it and it will surprise you. Pricy yes but worth every "nickle" david.ellsworth3@gmail.com
Don Leydens
Don Leydens
Vote #3 for the CBN wheel. One of the best lathe "tools" I've ever bought.
David Propst
Hi Jesper,
Get a radiused edge 180 grit CBN wheel. You will smile every time you use it and never regret it.
http://www.d-waytools.com/tools-diamond-grinding-wheels.html
~David
I doubt the extra $35 for the .........
JamieDonaldson
...1/4" radius on the edges of the new D-Way CBN wheels is worth the cost to most users, but I certainly encourage any grinder wheel shopping be focused on these products. I will never go back to any matrix stone wheels after using a CBN for about 8 mo. now! ;)
Fred Holder
Hello Jesper,
I've been using the diamond wheels that I purchased from Andre Martel in Canada several years ago. I use about an 80 grit wheel on the left side for shaping and a 360 wheel on the right side for sharpening. The people who are pushing the CBN wheels say the diamond wheels are no good. I've never used the DBN wheel, but am quite satisfied with Andre's diamond wheels. They too are expensive.
George Van Beynen
Hi Jesper,
I also have a radiused edge 180 grit CBN wheel. I wish I could afford two. I cannot believe how nice it is to grind on an always perfectly dressed and balanced wheel, soooooooooo smooth!
I would however always have a SG wheel around also for the high carbon steel and softer metals as I was told these can be harmful on a regular basis to the CBN.
Radius Edge
David Propst
Jamie,
For hollowing tool bits the radius edge makes sharpening so much easier. You can sharpen straight on and to the side, rather than angling the bit at an acute angle to the wheel. Ellsworth has long recommended rounding the edge of a conventional wheel for this purpose he asked Dave to do the same on a CBN wheel.
The radius is also really nice for scrapers.
~David
Ditto what david said.
John lucas
I dont have a radius edge on mine and i miss it. All my hollowing toos are sharpened that way
I discovered how Ellsworth sharpens .....
JamieDonaldson
...hollowing bits on a radiused edge wheel when I took a class with him in 1990. I've since devised several ways to accomplish this task with both a removeable bit holder that John Jordan sells, and its also easy to freehand the tools on an angled tool rest, without removing the bits from the tool shafts. This negates the necessity for a rounded edge on a wheel, and I saved $35 toward an 80 grit CBN wheel to go with my 180! :D
Jesper, Denmark
Jesper, Denmark
Thanks for all the suggestions and raving reviews of the CBN wheels. With a price of $170 or so, plus international freight, import duty and 25% VAT plus exorbitant import fees from either the postoffice or UPS, they are a bit outside my budget.
It will have to be blue or white Nortons with around 100 grit.
Don Orr
Aren't the Optigrind CBN wheels made in Europe? Austria I believe.
George Van Beynen
If you must stay with the non CBN wheels I would recommend the Norton SG ceramic abrasive wheels as they are durable and cut clean.
Don is correct, the Optigrind CBN wheels are made in Austria if that helps?
Jesper, Denmark
Jesper, Denmark
Thanks, I did find the Austrian company and have exchanged e-mails with them. The contact person is out till Monday, but recommended a 1-½" 180 grit whell. I will have to see if it will fit or if I should stay with 1".
Pricing is similar to the US, but the VAT adds some. Freight is quite reasonable.
Stay tuned................
Jesper, Denmark
Jesper, Denmark
I fund the Austrian Manufacturer, Holzer Hartstofftechnik, and have had som very helpful dialog with them. I will be ordering directly from them - 8" x 1½" 180 grit. It will take a little finagling to make it fit the Baldor grinder with the guards in place, but doable. When you deduct the high VAT (20% in Austria, I believe) the pricing is in the ballpark with the US and shipping is a very reasonable $15'ish.
sergio
I just bought a 8inch 80 grit CBN wheel from 3 way tools. Instead of sanding the shaft of my 7 inch Baldor to fit the bushing as recommended I had to sand the inside of the bushing that was machined very poorly with rough markings still on the surface. The operation was painful not having a milling machine. I use the CBN wheel for the occasional shaping of the tools and a Tormek for the final sharpening. Superior and faster combination in my view. Furthermore I can razor sharpen all my carpentry blades.
Opti-Grind wheels
Dale Bonertz
Jesper,
I purchased the Opti-grind wheels and you will love them. I now enjoy sharpening where before I kind of dreaded it do to the dust from the wheels.
Jesper, Denmark
Jesper, Denmark
The Optigrind arrived today directly from the manufacturer in Austria. It almost fit the grinder with the cast iron shrouds on. I needed to remove a little flange locator pin from the shaft and use both of the old flanges on the outboard side of the shaft. A washer between the endplate and the shroud made it 1½ mm clearance on both sides. The blue stone moved over to the left side for sharpening scrapers etc.
I have not had much time to test, but both sides are now better than before. CBN sharpened gouges seem smoother and the finish cuts are easier to control.
