Back in business!
Tony Reynolds
I got the new inverter installed today. The 3hp version is much larger than the 2hp so I had to drill and tap new mounting holes. Also had to file down the motor bracket at the hinge point so it didn't interfere with the inverter when loosening the belt.
Read the manual and figured out the parameters that needed programmed so the front panel controls would work. Before doing that, I learned how to run the lathe with just the keypad on the inverter. I have to say the keypad method is pretty nice. If the inverter was on the front of the lathe I'd just use that. The degree of control on the speed adjustment is pretty sweet. It maybe just me but it seems that this newer model of the Delta inverters is much smoother at lower speeds than the older version.
I may over time play with the ramp up and braking times to fit my style of use, but all in all I'm very pleased. Now back to work to make up for lost time creating inventory for the next show at the end of the September.
Just encase someone is looking to buy a new inverter I got mine from Charles Gumm at AutomatedPT.com and was very pleased with the service I received. No affiliation, just a happy customer.
Thanks for everyone's input.
Tony
