A55 Smoothing Plane
what glue to use
what glue to use
what glue to use
So I'm finally getting back to the hollow vessel with the cracked neck. If you followed this it had a cracked neck and I put string around it to cover them up. Hated it. Now I have some very thin black wire. I doubt seriously that I can just wrap it around the vessel and stick it through a hole, tie it off and be done with it.
I think I need to put some glue down so the wire will stick to it as I wrap. I want to do something similar to gluing gold leaf down where the glue is tacky and dries afterwords to hold the wire.
I also need to push the wire through a small hole and then somehow secure it inside the vessel. Can't reach through the lid with anything larger than forceps so this might get interesting. I'm thinking that I will push enough wire through the hole so can crab it with the forceps. Then apply some thin CA to the wire just above the hole and pull it taught. Hopefully enough glue will get down into the hole to hold the wire. Not real sure how to cut it off then.
Any ideas. Won't get back to this until later this week.
Re: what glue to use
Epoxy
David Walser
John - For what you're trying to do, I think I would use some 60 minute epoxy that had been dyed black. After first coating with wax everywhere I didn't want the epoxy to stick, I'd paint the neck of the vase with a coat of the black epoxy. Then, I'd wrap the neck with the black wire, embedding the wire in the epoxy as I went. I don't think I'd feel a need to do anything about the wire inside the neck of the vase. I'd be fairly confident that the epoxy in hole would secure the end of the wire.
I'd try to keep the epoxy off the top of the wire, but I'm pretty sure I'd need to clean up the top surface with q-tips dipped in acetone. By dying the epoxy black, I would hope that any gaps in the wire wrap would be less noticeable and would make the glue disappear, too.
Good luck!
galen Vetterick
You wanted to do some metal spinning so make a metal collar that fits your shape and set it in epoxy.
Not sure how thin of wire you have but you'll have to work from the top down as I recall the neck shape.
What if you soldered it as you went enough to hold it then tin the whole finished collar and add any pinta to it for another effect.
I know you'll find a way.
Sounds interesting will consider that option
John lucas
Looking really hard at taking that class at Marc Adams. Ive been srudying mat spinning for years and even startedmaking the tool rest and tools but then moved and it all got put up. I think i just need a little bith push and it would be fun spending time with Michael Mocho anyway.
Harry Robinette
Harry Robinette
John I think I would wrap the wire like David Ellsworth dose his wrap on his handles. This way you need no holes.The wire will tighten when you pull the end through. Then use the epoxy over it.
I just seen this wrapping type somewhere in the last month or so but can't remember where. I'm all most positive D Ellsworth dose his handles with this self locking wrap. Hope you get it figured out.
I would use a wrap technique like.....
JamieDonaldson
...wrapping line guides on a spinning rod. With a fairly light gauge wire you form a loop, then overwrap the loop and finish off by pulling the loop and tag end of the wrap under to hold it.
John lucas
Harry i thought about that but dont think it will wrap like that on that much of a taper
galen Vetterick
Not sure how much support you need to the wood neck but it would be easy to wrap copper tape used for stained glass and then solder over it and add a black patina if that is the color you are after. Got a friend with a kiln? Make a clay mold of the neck and fire it with any color you wish and use it as a collar.
Don Stephan
While epoxy might adhere well to the surface and wire, cleanup of excess and squeezeout not easy. You might consider wrapping the wire, and after finished brush on a couple thin coats of shellac. With denat alcohol, it can easily be removed if doesn't look good or gets on too thick.
Clean up after epoxy is very easy. Just use Alcohol. I do it all the time. I'm a big epoxy fan but not sure it's right for this. The big reason is the angle I have to wrap the wire. it wants to slip up over itself which is why I wanted a somewhat tacky glue.
I may just turn a scrap piece and to the same shape and try the black epoxy. If I mix it thin and brush it on pretty thin it won't run. I can wax up to my line to make the clean up easier.
Jim H
What about contact cement?
You would have to set up a jig to keep the roll of wire out of the way and feed out only a couple of feet at a time so you can apply and let the glue on the wire dry without touching itself. If I remember from the last time I used it correctly, I was able to rub off the excess quite easily.
Re: what glue to use (LONG)
Doug Trembath
Sorry, John, kinda late to the party, but I have a good solution I have used successfully in this instance.
One, go to Harbor Freight and buy some LONG needle nose pliers, I bought a set many years ago and they work so well...
Secondly, pull the approximate length of wire needed repeatedly through some steel wool or sandpaper to clean the outside so the epoxy bond will have some integrity.
Turn a set of mandrels (jam chucks) which will allow you to re-chuck the piece opening and foot. This can be tricky, because you have to provide an access to the wire, so it must be hollow and have lateral holes as well. Apply some rubber dampener, (I use rubber shelf liner) or something similar so it will grab and hold the vessel while you rotate it, to allow you to place sufficient pressure on the wind of the wire to get wraps with zero gapping on the wire. Drill a small hole where you wish the wraps to start, and where you want it to finish. Apply a fairly liberal base coat of epoxy to the neck. Thread the wire into the start hole from the outside, (smallest diameter, DAMHIKT) and out of the mouth of the vessel. Believe it or not, temporarily tie a knot in the end of the wire to stop it from coming out of the vessel. Then chuck it up and use the hand wheel to control the tension, and carefully rotate the vessel and feed the wire under tension until it achieves the wrap length you desire. While holding tension on the wraps, feed the loose end through the final hole, reach in and pull it taut. Tie the wire off to the tool rest or something after setting the rotational stop on the lathe shaft to prevent loss of tension. Apply your epoxy then, and let it set. When the epoxy has cured sufficiently, carefully use the long needle nose to break the wire inside at each end. I know this sounds crazy, but you should end up with a kink at each end of the wires sufficient to allow a supplemental application of epoxy to the inside which will secure the ends.
A lot of effort to save a hollow vessel, but if you want to save this one, it will work.
After all that being said, however, I know that when I'm in production mode, I'd just place it into the burn barrel, grab another rough-out, and make another just like it. Production turning can be a lot less fun, though...
Sometimes a piece is just worth the extra effort. In that case, I do whatever it needs to become done.
If this isn't clear, email me and I'll try to make it more so...
Best of luck with it, John...
Doug Trembath
Doug thanks. This piece isn't really worth the effort other than simply as a learning tool. If it doesn't come out well it will be tossed but I will have learned something. My biggest problem is that I can't reach in to cut or break the wire with anything that cuts anyway. I might be able to bend it back and forth with the forceps enough times to break it if it's not too soft of a wire. That would assume it's glued in the hole well enough or it might simply pop out after I break it off.
I won't have time to do any of this for another week so it's just sitting on the bench trying to figure out what to tell me to do.
