I just picked up my fathers Walker-Turner lathe and want to get it back up and running again. It turns fine when between centers but binds up when using a face plate. I have had the headstock apart numerous times but I just can't sort out why the spindle binds when using a plate. I am not certain of the arrangement of the bearings, spacers, retainers etc. in the headstock. I also suspect the thrust bearing may be incorrect. So.....does any one have a manual with a blow up/parts arrangement for a W-T Model/Serial Number 11L314 lathe. It is a 12" swing, gap bed, 36" between centers. It is a bit of an oddball which perhaps is why I like it. Thanks for any help. I would be happy to pay a reasonable fee for a manual. Thanks. Ron.
You might also scan the "General Line Catalogs" for more information on your specific model which may provide more leads for further digging! This is an awesome web site, and a real resource - kudos to those who took the time to put up all of this information and who maintain the site!
When you say "binds up", what do you mean? Does the lathe belt start to make noise due to slipping, or what?
Also, can you feel any movement if you try to move the spindle up and down do so at each end but one at the time?
What I would guess at this stage with no more info is there is slop in the casting where the bearing are.
Does the first link that was given show the correct lathe? I notice on it that the front bearing is a double on that pictorial.
Sometimes during the life of these older machines one or more of the bearings will go bad and the whole bearing will turn in the casting causing it to enlarge the hole. You said you have had it apart, do the bearings slip in and out and feel really lose in the holes?
You can also remove the end plates and turn spindle by hand and watch the bearings action.
You should be able to get bearings if needed from MSC, Enco etc but you'll need to put digital calipers on it and measure hole, outside diameter and it's width. You'll need it in metric and sae probably in order to find a fit, you can also measure the casing and compare that to outside of bearing diameter. The bearings should be tight. Most times they have to be pressed in and out of casings.
Its also very possible someone put wrong bearing in it in the past so watch for that.
I've got a 1945 Logan metal lathe that still has the original bearings, but they needed a good soaking and washing out when I rebuilt it. Point is don't just throw them out without cleaning and then rolling them with your fingers, if they move smoothly with no rough places in the rotation then repack them with bearing grease and reinstall.
WARNING: do not rotate bearing with compressed air, it's ok to blow them out with it, but hold the bearing so it does NOT turn. These bearings are not made for high rpm and can come apart in your hand. It would be like a mini hand grenade.
First of all THANKS to Rob and Don for your research and comments. After going to the "vintage" website I found the head stock blow ups for my machine. Then added the suggestions from Don about cleaning up the bearings and voila, it runs just slightly rougher than a Rolex!!! The problem was that in the distant past a spacer was left out between the thrust bearing and the drive pulley that allowed the spindle to drift in the headstock which caused the face plate to rub on the head stock cover plate. I made and installed a replacement spacer. The missing spacer was shown in the parts assembly blow up. It runs smooth without heating the bearings so I think it is ready to go. Thanks for all your guidance...that is what makes this forum so awesome. Ron.
