molds under anchorseal
Sergio
Hello, I have problem. I just started to use the paraffin emulsion (Anchorseal) on my rough out bowls and I'm storing them in the basement which is preatty dry. They are developing molds. My question are do I have to change the location with a drier place and will these mold go through the depth of the wood? Thank for your suggestions.
P.S. I wonder what Buonarroti would have said reading the discussion on creativity!
Re: molds under anchorseal
His Input
Where'sa my chisel?
Re: His Input
Sergio
where is the brush...maybe...
Re: Forgot something
Sergio
y
Bill Jacksonville, NC
One reason do not end seal after rough turning. I get mold growth on caning wax end sealed blanks stored in my woodshed. Live in zone 5 worst for mold growth. On spindle & bowl blanks normally end up cutting away mold on ends.
Recommend removing anchor seal and let blanks air dry naturally. Have a few bowls with mold stain which could not turn away. Believe mold spores already in the wood just not visiable while rough turning.
I sometimes want to eliminate the ...
JamieDonaldson
...potential for mold growth before applying green wood sealer, and a quick spritz with a diluted Clorox solution usually does the job. My roughed blanks are not anywhere close to form of the final product, and most of the moldy wood will be turner away after storage. And most of my wood to be stored is not really dripping wet, because I try to gather it during sap down season if I have that option.
Re: I sometimes want to eliminate the ...
sergiov
Thank for your insights. I tried not to use anchorseal but I got too many cracking. Anchorseal seems to reduce them. The clorox idea seems very logical but I wander if the smell will persist being mine utility bowls.
Some parts of the country, certain times of the year, some wood species just prone to mole growth. Mold needs air, moisture, and food to grow. Whether buy or harvest our wood for turning mold spores may or may not be present. Mold spores normally air born where ever we live.
Only real way to eliminate mold is control moisture. We know from extensive research normally mold does not grow on wood with MC below 20-22 percent.
We also know from extensive research drying wood simply a water removal process. To sum up this process in one word talking about evaporation! Because we are good know If we reduce the mass of wood (rough turn) speed up that drying process.
If we store that rough turned blank properly with just simple air circulation, we eliminate MC and make wood stronger over time. Problem is if we re-seal that wood with green wood or anchor seal how does moisture escape and eliminate mold growth?
Bill Howatt
There are 2 kinds of Anchorseal, one for colder climates has antifreeze in it which I believe is just some alcohol. I got some non-antifreeze type once and I think, and I emphasize the "think", that it was more prone to molding. LIke I said, only an impression at best since there are so many factors involved in drying.
While I can't argue with success, chlorine bleach is not a recommended treatment for mold removal or control and even degrades to a food for the mold.
As was stated, there is a MC that promotes growth and once dryer than that it will not grow.
Having had some grief with black mold my approach now is:
Only put it on the exterior end-grain. This is the crack-prone area due to fast drying.
If you are concerned this is not enough, wrap the bowls in newspaper but change them frequently, every day at first if they are real damp. If you don't change them you will just be sustaining a damp environment for the mold. The wrapped bowls can be placed in a box or a paper garden bag.
Don't throw a bunch of wet shavings into the box since it just keeps the MC where mold likes it.
Monitor the drying, don't just put them aside and forget about them until the MC is well down - you can tell by weight or newspaper if used, is no longer getting damp quickly.
Mold control is contrary to what we are told for cracking control since it says dry quicker rather than slower so a balance has to be achieved.
A strange happening:
I had some hard maple from a sentimental tree. Unfortunately, it got black mold because of my in attention and also the logs had sat around a bit longer than normal before being cut and roughed. The blanks developed black mold which was rather upsetting. Now the strange part, the roughed blanks have sat around for about 4 yrs in my basement and the black staining is now gone although it was obvious for the first years. Didn't think that would happen. Anybody else experience this?
Bill
