Have a question? Ask Woody!
Dyes & Box Elder
Dyes & Box Elder
Dyes & Box Elder
Just to give an example of using TransTint dyes on Box Elder, this jar was done two years ago and has not faded at all.
And a tip for preserving the "original" color: Apply your dyes as soon as you can after your first turning. As mentioned in another thread, the fresh-cut color of wood tends to fade with time. That goes triple for BE as the reds are phenol compounds that are very fragile. I've had BE that looked like it was bleeding when first turned but during drying lost most of its color. Putting on the dye will preserve the "scheme" so that you can reapply later if needed.
Re: Dyes & Box Elder
Thanks Mark
GaryG in MD
Good info! ...GG
