success!
success!
success!
GaryG in MD
Like many of you, I'm sure, I regret the inevitable loss of the beautiful red coloration in box elder as it ages (mostly by exposure to UV) to brown.
I've read people here (was it Jamie, perhaps?) saying to add artificial color by air brushing. I don't have the "stuff" to air brush (in either the literal or figurative senses), so today I sought an alternative. I made a pen with box elder (and black Ti) that I absolutely had to keep the red in.
I considered water colors, but I didn't really want to use water, and I figured that if I dry brushed it, I couldn't blend the colors to get the desired result. Looking through my art drawer, I found a set of 36 Grumbacher oil pastels (about 40 years old) still in excellent condition. (Don't you just love it when you keep stuff, and it stands the test of time? But that's meat for another thread for Charlie or Steve to run with...). Most finishes work over oils, so that sounds like a good solution to me.
I've always been impressed with how pastels can be blended to achieve any color desired. So I started playing around on some scrap (or skip the 's') box elder bits to see if I could accomplish a match for the red color. Yes! I could. Just three colors. But would it end up looking real? I'm picky, and if it looked fake, I just couldn't do it. Well, nothing ventured..., as they say.
I carefully drew very light, spaced lines of the darkest color, a deep, very slightly bluish red, onto the pen body over the real color, taking great care to stay "in the lines". I went over the area, first with an ocher light orange, and then with a white. Then I blended it well with a pointed, rolled-paper blending stick, and carefully wiped off any excess with a tissue. Hey, not bad. A good match. Just a little more intense than the real deal, but that's good -- it makes a nice statement on a pen. And it seems to be sticking really well. I don't know if it's a "permanent" color, but it will certainly last a LOT longer than the red wood!
Will it stand the test of my pen finish? I use the new Stick Fast CA kit. I absolutely LOVE it. I fought with pen finishes and was losing the battle till I found this. It really works perfectly. No yellowing (upon which I absolutely insist), very quick and easy, and can leave a satin or gloss finish, as desired. The first "seal" coat is a specially formulated 'thin' CA. I put it over the pastels with the lathe on, and there was no problem -- no running or spreading or movement of the color. It just locked in under the CA. Yes! Love it. [Unfortunately, the photo is still on my camera, so for now, you'll just have to take my word for it. But I will post it soon.] (Note to self...)
So if you want to keep your box elder red permanently, just follow the above instructions. Here's my recipe. The three Grumbacher colors I used are
1) (a deep red) "22-10",
2) (a light orangy ocher) "22-3", and
3) (white) "22-1)
As I say, these pastels are probably 40 years old, and Grumbacher was bought out by Prismacolor, so I can't say if they use the same numbering system these days. You can sometimes get the originals on eBay. But even if they're not the identical numbers, my descriptions above should get you off to a good start anyway.
I am very enthusiastic about this. I have beat Mother Nature on this one!
...GG
Re: success!
Mike Stafford
Re: success!
Mike Stafford
What is it that they say about no pictures?
Re: success!
Oh be careful
Dale Bonertz
Gary. The Titanic thought they beat mother nature. :) I am anxiously waiting to see a picture.
Re: success!
Good on you Gary! I have been painting.......
JamieDonaldson
...the BoxElder reds with alcohol diluted red TransTint, and it's working fine by using several dilution ratios to match the range of reds in the BE. A small paintbrush application(s) allows the color to penetrate better than airbrushing, equipment I don't have anyway. Years ago John Dodge Meyer used Marshall photo retouching pigments(oils) to suppliment his potentially fading colors, and that's the source of my investigations into making the colors lightfast.
Re: success!
Re: success!
charlie belden
Sometimes it pays to hang on to things - if you have the space to store them - and can remember you have them ; )
While purists may object to coloring the wood for any reason, I think that as long as it enhances the wood, rather than hide it, it's all good.
Thanks for experimenting - and then sharing what you've found. This is the type of thing that keeps wood turning growing in so many directions so quickly.
Alby Hall, from New Zealand, used colored pencils and neats foot oil to color areas of a burl wall plaque. The result is quite striking.
Keep playing - and discovering!
Re: success!
I thought it was you...
GaryG in MD
Yeah, alcohol-diluted red Transtint -- I can see how that would work.
Excellent idea. I may have to try that too and compare results. ...GG
Re: success!
thanks, Charlie...
GaryG in MD
I appreciate your support! ...GG
Re: success!
Ditto on the TT
I now use TT red, red mahogany, medium brown, and blue, plus a couple of Prisma Color fine line pens to "replace" the BE coloration. Ultra-Fine art brushes do nicely.
Re: success!
thanks Mark...
GaryG in MD
Good tips on the colors and pens.
Lots of options!
My BE will never fade again!
...GG
Re: success!
OK, Mike and Dale, uncle...
GaryG in MD
I got it off the camera just for you guys!
Here you go
I filled the worm holes with graphite powder and CA. No, the black didn't "run". I was surprised too.
I don't normally post pix of kit pens, but here's my latest set, including this one,
top to bottom:
gold Euro, diagonal grain zebrawood (I think? else you tell me...);
black TN Comfort, color-augmented box elder;
chrome Comfort, purpleheart; and
black enamel Comfort, birdseye maple.
Oops. I see I've got the grain match off on the Euro.
Yes, it does match. I'll go rotate that right now!
C&C welcome, GG
Re: success!
Mike Stafford
Re: OK, Mike and Dale, uncle...
Mike Stafford
Looks great Gary and the paint looks very realistic. I shall consider getting you a beret as you have now entered the realm of artistry.
Re: success!
:-)  Thanks Mike
GaryG in MD
I have to admit it came out a lot better than I expected.
The key is adding the color sparingly and using the blending stick.
I adjusted the color at the end by applying it directly to the tip of the blending stick -- worked great.
I like the idea of the diluted dyes too, but I fear they may migrate by wicking.
The pastels stay where you put them.
...GG
Re: success!
Dale Bonertz
Very nice and authentic looking.
