Chrome Plated Stopper Use
Barbara Gill
I have found a great use for those nasty chrome plated stoppers. I hated to throw the corroded thing away and am glad I didn't.
Re: Chrome Plated Stopper Use
Just don't forget and try to drink from it!
Rob Wallace
Be sure the rubber seal is gasoline resistant!!
Rob Wallace
Barbara:
As long as the rubber parts of the stopper are gasoline-safe you should be OK. The last thing you want to do is to contaminate your gasoline if it is capable of dissolving the rubber and/or leaching contaminants from the rubber into the gasoline. Burning such fuel in an engine could quickly lead to problems in fuel line, carburetor, and piston/valve systems.
You might try to run a simple test to see if the rubber is gasoline resistant by soaking the rubber portion of the stopper in some gas in a small container for 5 minutes or so, and see if there is any breakdown or softening of the rubber after immersion in gasoline. If any rubber "wipes away" or deforms significantly when you rub or press on it, you may want to stop using the stopper immediately. Although rubber gaskets on wine bottle stoppers are suitable for use with aqueous alcoholic liquids, their resistance to gasoline should be checked. Different kinds of rubber materials may be used with different stopper kits (of different levels of quality), so you can't assume all of these materials are the same kind of rubber, or that they are all gasoline resistant!
I'd hate to see you foul-up your chainsaw or other engines by using a chemically incompatible rubber material on your gasoline can - doing so can be FAR more costly to repair than just buying a new can with a proper gas-resistant cap.
Rob Wallace
Keith Newton
Well, that looks great, but you had better do one for the big can, so your sawmill won't get jealous, and cranky, or maybe uncranky. ha
Re: Be sure the rubber seal is gasoline resistant!
Barbara Gill
Since the gas doesn't touch the stopper I never thought it would be a problem. I will check it out.
Thank you.
Barbara Gill
Keith, I no longer operate the saw mill. I have had my knees replaced and given up milling. The sawmill is for sale. 😊
Rob Wallace
Gasoline vapors will, continuously, in storage....
Rob Wallace
.....as well as residual liquid on the inside wall of the tube.
Unless you are sure, I'd say it's not worth the risk of contaminating your gas...
Rob
Re: Gasoline vapors will, continuously, in storage
Barbara Gill
I have the stopper sitting in some gas and a cork sealing the can. I agree about a better container but didn't have time to go get one.
Keith Newton
Sorry to hear that Barbra, I thought the back was supposed to be the demise of us sawyers. But my knees have been killing me lately too, so I might need to follow your lead down the replacement path. How are they doing now? I hope you doing well.
Barbara Gill
I never have had back problems. My knees are now 30 years younger but the rest of me is still 67. LOL
If you need knee replacement there is no point in waiting. The cartilage won't come back.
Rob, Thank You!
Barbara Gill
You were right about the rubber on that stopper. Shoot even the rubber wasn't good enough for gas. The chrome sure wasn't good enough for wine. I only buy Ruth's stoppers now. In fact I have been buying them as long as she has been selling them.
Back to the gas. I left the stopper in a jar of gas. It was not deep enough to touch the rubber but I had tilted the jar so the gas would wet the rubber. I left it overnight. As Rob warned, the black rubber came off on my fingers.
Rob Wallace
Re: Rob, Thank You!
Rob Wallace
Glad we caught this before something bad happened to the gas!
"Better things, for better living, through Chemistry...."
As Red Green says, "We're all in this together...!
Rob
Ruth's Stoppers
Barbara Gill
Are so well made they are gasoline resistant. Of course I would never waste on in a gas can.
