I'd Recommend John Jordan's DVD on Aesthetics.
Greg Haugen
I'd highly recommend John's Aesthetics DVD.
First off, what did you do with the bowl after you turned it? Let's give you the benefit of the the doubt and say the walls were perfectly even and a 1/4" thick. Best option would be to place it in a cardboard box or brown paper bag. IF it was soaking wet, I'd have the box/bag closed for a week or so and then opened. If it wasn't slinging water too bad, I'd start with it open. For the best results, in a cool, calm place-like the basement floor. Any green wood, even finish turned, left open to moving air on the shelf in a hot shop will usually be a cracked piece. Heat and air movement dries wood, usually too fast. Also how was the grain balanced? Was the piece centered and balanced in line with the pith and growth rings? Limb wood or trunk wood doesn't matter to me as long as the grain is balanced. The common error with limb wood is the pith is off centered. Water in the limb is effected by gravity so the bottom of the limbs has wider growth rings than the top. The correct way to cut these pieces is to center the piece on the pith. So you'd have narrow blank and one deep blank. IF you cut it to have two equal pieces, not have the pith centered, you'll have more issues. Personally, I like limb wood. I can usually get deeper blanks off of the first few limbs than I can the trunk often times. The narrow blank...usually is firewood.
Wood Cracks for three reasons:
1)It was cracked already and you couldn't see it before.
2)Being dried too fast and not controlled
3)Unbalanced stresses; either from wall thickness or grain balance
Also Barry, where in the wing did it crack; edge, middle, or at the bowl? Even though it took several days for it to crack, that doesn't necessarily point to one issue or the other. That was just the "free" water drying before the "bound" water. Free water is mostly what gets you wet and your lathe rusty. Bound water is the cellular water that causes the warping and some times cracks.
