Installed Doc's remote control in less than 30 min
Aage Rendalen
Thanks to Doc Green I now have a remote control for my PM 3520B. Not only was it very easy and quick to do, but it cost me less than $20. Here's a summary of Doc's recipe:
1. Open the start button panel.
2. Remove 4" yellow wire.
3. Insert a 16-2 gauge lamp cord into the headstock from the back.
4. Crimp on a spade connector on one line, a female connector on the other and attach them to the leads used by the yellow wire.
5. Connect a toggle switch to the other end of the line.
The only complication was that I had to grind down the outside of the 16 gauge spade connector from Lowe's to fit the PM's mount. The most time-consuming part was stripping the wires and crimping on the connectors. That says something about how easy this is, when you have Doc's recipe.
I bought 10 feet of wire and ended up using 9 ft. of it (I used another route than Doc's).
