Veritas - Innovation in Tools
Bonnie Klein Jig
Bonnie Klein Jig
Bonnie Klein Jig
Clyde Collier
Does anyone know how to eliminate the lash from the screw that advances the work piece perpendicular to the ways?
Re: Bonnie Klein Jig
It's been a long time since I've held a Klein jig in my hands. Perhaps you can put a brass shim in the dovetails.
Bill Turpin in WNC mountains
Contact Bonnie at email link on www.bonnieklein.com. She probably knows how
Dennis in Southern Oregon
Clyde, while the spindle has provisions to remove backlash, the cross-feed apparent does not and, indeed, it has considerable backlash. However, I have never found this to be a problem. I am careful to make all measurements with the cross-feed snugged in the same direction, namely, the direction that advances the workpiece toward the cutter. The cutter will always try to repel the workpiece so backlash should never be an issue.
Dennis
kvaughan
Bonnie used a Taig Lathe cross feed. The lathe is still being marketed and though small does some good metal work.
Taig changed the cross feed screw assembly a few years back, but I have not yet made the change on mine.
If the cross slide is loose (sloppy) there are gibs that can be adjusted to remove the side play.
The Taig cross feed screw is designed to have minimal back lash by always working in the same direction. While one can futz with the system to reduce the backlash, always backing off and re-approaching the desired position will provide a solid setting.
robo hippy
Well, maybe I understand this now. By 'lash' you meant 'back lash' as in some play in the shaft? I took a workshop with Bonnie some years back, and this play is intended. You can use the grub screws to take most of the play out. Bonnie's method was to hold your finger, very gently on the box part as you advanced it into the cutter. As the box part screws in, you pull or push VERY gently into the cutter, and as you back it out, you push or pull VERY gently away from the cutter. Too much pressure, and you can unscrew the box part. This is to prevent tear out of the threads as you back the part off the cutter and the cutter is still spinning. This is now habit with me. I don't know that it makes any real difference, but that was the theory behind it.
robo hippy
Don Evans
These parts on all metal lathes have back lash, it comes from the ACME screw and nuts that are used. All screws and nuts have it take any 1/2" screw and put a nut on it then rock it on the threads and you will see it has slop in it. This stop binding and SAE are cut at 60 deg normally, don't know what ACME is off hand.
When running a metal lathe using the dial markings when you change direction on the screw you first move it to take up the slop, then read the dial and from that point start going by the dial to move it the number of divisions you want. The slop should not get in the way at all when done correctly.
The gibs will not help this at all but they should be just snug enough to take up play but not make it hard to turn the dial or screw, they should keep vibration from moving the devise however.
Don
