some mirrors just fight me
I decided to make one more mirror before I go to Texas. Pulled out some purple heart with the intention of routing designs in it. The longer lines went perfectly. then I set it up to do the shorter lines. something slipped between the time I set it up and the time I made the first route. they went too long. OK not too bad there just isn't the contrast in size that I wanted.
So I continue to route. Now one of the problems with cutting this way is it's very hard to always cut downhill with the grain. so it chips out 2 different areas. so I figure I'll just turn those areas into a cove. Well that didn't work too bad but sure ruined the design I had drawn out. OH well it doesn't look to bad.
did I mention that I always measure my new mirror glass because it's not 4" any more. I did that and turned the opening before doing all the routing. I got finished, drilled it, put the handle in. Applied the finish and buffed it. got ready to put the glass in and it's .045" too large. Something slipped between me measuring the glass and using the calipers to judge the opening.
Now if I had a 3520B it wouldn't be a problem. I'd just chuck up the mirror, handle and all. Move the headstock to the end of the lathe and re turn the opening by moving the bed extension down and adding the tool rest. However I have a 3520A and don't have that option. The handle is 1" too long to clear the bed. I can move the headstock to the end but then I don't have a way to support tool. OH well. I'll use my head tomorrow and come up with something.
