Remote Switch - Success
Steve Criscenzo
I used Doc Green's "little yellow wire" method to add a remote switch for my PM 3520. I found a low cost motor switch at Amazon. I like it because of the large stop bar. I could not mount the switch on my tailstock as Doc shows due to tilt away for the tailstock. Instead, I drilled and tapped two 10x32 holes in the base and attached an outdoor outlet box. Works like a champ.
Thanks Doc!
Re: Remote Switch - Success
Switch Envy
Doc Green
Good deal, Steve! I'm glad it worked.
Your switch is a little bigger than the ones I used. Now I have switch envy!
~Doc
Rob Wallace
Re: Switch Envy
Rob Wallace
It's not how big the switch is, it's how you use it that matters.....
Rob
paul grover(sc.)
IS THERE A WIREING DIAGRAM AVALIABLE TO WIRE THE SWITCH USING THE YELLOW WIRE?
Steve Criscenzo
Go to Doc Green's we site and it is in the recent article section.
Steve
Link to the article *LINK*
Doc Green
Shows how to install a remote switch on a PM 3520.
http://www.docgreenwoodturner.com/remswitch.html
Home Page
