rope neck
rope neck
rope neck
I took everyone suggestion and covered the neck of this vessel with rope. If you remember it cracked while hollowing and I saved it with CA glue but didn't like that and was afraid it might crack later on.
I turned a collar to put inside and then wrapped the twine around it with strips of medium CA down the side to help secure the twice. Drilled a hole in the vessel and fed the twice through. I solidified about 2" of the twine with thin CA so I could feed it through the hole and then pulled it through with some curved forceps.
Not sure I like it now. It kind of ruins the curve going up to the neck but it is sellable this way so will probably go in the next show I do
Re: rope neck
Re: rope neck
Terry Scott
Hi John I think a finner string would have looked better then it would have followed the curve better
Or maybe copper wire with verdigris
Re: rope neck
Re: rope neck
Terry I thought that also just didn't have anything around the house. I had some fairly thick black thread but wasn't sure that would work with this. maybe it would have if I dyed the collar black. Maybe next time.
Re: rope neck
I agree with Terry...
GaryG in MD
This doesn't work for me, but I think brass or copper wire would be a definite improvement and might even be "nice". ...GG
