If I had a larger lathe . . .
charlie belden
I might have a go at THIS (sugar maple, died and dried standing). That's a 24" straight edge. Imagine what's inside to reveal. where the four roots come together.
Re: If I had a larger lathe . . .
Dale Bonertz
Is it all that it is CRACKED up to be. You might want to stand in the other room when you turn it, in case it comes apart. :) Never know though there may be a beautiful piece in the center of it.
That actually appears to be a......
JamieDonaldson
...crotch with 4 branches, and with all the cracking you probably wouldn't have very large pieces worth turning. Determining how to saw this apart is always a mystery, because they often have center rot and bark inclusions, just as is likely here. You won't know what you have until you attack with the saw! ;)
Re: That actually appears to be a......
charlie belden
It may be that this is in fact a four branch crotch - the branches almost 90 degrees apart. From looking at the bottom of the piece there appears to be only one pith on that end - so the piths of the branches may come together in the middle of the bottom. THAT could make for an interesting bowl - maybe with a single pith located in the center of the bottom of the bowl. That could be plugged if it presents a problem.
The idea would be to turn INSIDE the four branch piths. Within the branch pith locations there appears to be sound wood, the deep cracks extending from the OUTSIDE to the pith of the branches. Because the wood dried standing, there shouldn't be a whole lot of movement once the piece is turned. This of course assumes that there are no major bark inclusions, internal rot - or - nails, wires, staples or who knows what inside. A lower piece, if this piece is in fact branch crotch not root crotch, did have fence staples three or four inches into the trunk. A friend found fence staples in the pieces he got - discovering them with his bandsaw blade (ouch). Fortunately the staples were relatively soft steel so they just dulled the hell out of the blade rather than tearing teeth off.
If anything interesting comes out of this chunk of wood I'll post photos.
