A request was made to chat about ferrules. When making a handle what do you use? Are they super glued string or turned plumbing parts? Does the tool use dictate the type?
Join us Wednesday night a 9:30 EDT and let us know what you do.
The only thing missing is the ferrule's I use. I use brass compression nuts or tapered nuts. I turn the wood down to just a hair larger than the inside threads. then screw it on. I pull it back off and add just a little epoxy and then screw it back on. Then I just turn the brass hex down to round.
The tapered brass nut fittings have a thread on one side and smaller smooth hole on the other. The outside starts as a hex and then tapers down to round. These look really great after you turn the hex away. I use them mostly for my scratch awls or ice picks but have made a few smaller tools with them.
copper pipe and copper end caps make great ferrules
Another option is one I learned from Clay Foster. Turn the tenon on the end of the handle. split it with a bandsaw. then apply a screw hose clamp to the tenon to hold the tool in. when you want to sharpen the tool just loosen the screw clamp and pull the blade out. Makes it much easier to sharpen tools that have a long heavy handle.
....improves the hose clamp ferrule set-up John. Turn a slight recess in the handle sized to fit the width of the clamp, so that when it is loosened for tool removal it doesn't slide off and disappear in the shavings forever! You don't need to ask how I learned that lesson!
