Fir Burl
Fir Burl
Fir Burl
robo hippy
I had a friend over for some turning and coring help. He had a good sized chunk of burl that he thought was madrone. Well, the first cut with the chainsaw said absolutely no, because, madrone has almost no scent, and final conclusion was that it was fir, and there is a lot of that here. Well, that stuff was just plain nasty, and one of the most difficult pieces I have ever cored, and maybe turned for that matter. I am glad he will be sanding it out. I was able to get a fairly clean and smooth surface, mostly from scrapers at shear angle, and the scrapers were swept back, so a long surface. I tried to core with his McNaughton blades, which still had the spear point on them, and it was pretty much unmanageable. I had a large tenon (I do use them under 'special' circumstances) on the end, and piece was about 8 inches deep by 12 diameter. The extra depth added to the vibration. Dusty, chattery, vibrating, sticky, pitchy, dusty residue every where in the turning room, and I was covered with the stuff from head to toe. Since I was sweating, it stuck twice as bad. I am not sure if the dust will come out in the wash. Never more!
robo hippy
Re: Fir Burl
Dennis in Southern Oregon
Re: Fir Burl
Please clarify something for me. You said that his McNaughton "still had the spear point on it". I bought mine ten years or so ago and they had chisel points on them. Much later I saw some with spear points and I assumed that they were an updated design. What do your use and why?
Dennis
Re: Fir Burl
Re: Fir Burl
robo hippy
The 'old' McNaughton blades had an angled tip that was all on one side of the blade. The 'newer' version has a spear point that is centered on the blade. This makes a huge difference in cutting. Mostly because with the cutter centered on the blade, it is easier to correct the cut by taking some off the inside of the kerf rather than always having to open up the cut on the outside. This was a Mike Mahoney idea. I don't like the added surface area on the cutter, and ground them off square. They still cut fine, and with less cutting pressure.
robo hippy
