Re: Kilns
Greg Haugen
The advantage of a kiln is time. The general rule of thumb is 1" of wood per year for air drying. In my kiln, I can dry 30 bowls in 4 weeks. It's a 3/4 size upright freezer, with all of the mechanical components removed. There's a grid of 1/2" holes 5"-6" apart on the top and the floor with a light bulb in the center. No fans. Hot air rises and pushes out the top, while it pulls fresh air in the bottom. I've used this style of kiln since '08. The original instructions, attached below, came from Kelly Dunn of Hawaii.
Refigerator kiln,
Get an old fridge or standing freezer. Free for the taking at landfill
dropoffs and applience repair shops.
Take out all things not needed. On the fridge cut out or take out the
divider section between the fridge and freezer compartments.
Drill some half inch holes in the top and bottom roughly four inches
apart. Get an outlet box and a ceramic lightbulb holder. Put that in
the bottom center. If the plug in wire for the fridge is still good
you can use that. Make a metal cowling to go over the light bulb. This
is just in case so nothing can fall and break the bulb and cause a
spark. Often aluminum was taken out of the inbetween section that is
perfect for a cowling.
The shelving, use ones from fridges and freezers that fit your
unit,can be started right above the light.
Rough turn your pieces to about an inch thick.
Bowls must be coated on the outside with green wood sealer to prevent
from cracking.Pen blanks and small items up to you.
Stack on the bowl sides leaving a very small space for air to travel
in the bowl. And fill the thing up. If you are not in a hurry a 40
watt light bulb can be used and as pieces dry pull them out and rotate
work from the top of the kiln to the bottom. No fan is needed with
this kiln. An air convection current will be created and will work for
you 24/7.
You will need a moisture meter. Even a cheap one will work for this.
Start with a 40 watt bulb. When the bowls are around 14 to 16 %
moisture pop in a 60 watt bulb. With the 40 watt bulb moisture will
drip from this thing. You can leave it or wipe it dry. That will all
be gone by the time you put in your 60 watt bulb. which should four
weeks or under for sopping wet bowls. In about a week the bowls should
be about 12% or less. Pop in a 75 watt bulb. It should be under a week
and the work will be 6 to 8%.If your kiln is in a cold area you may to
go up a 100 watt bulb to do the job. Turn it off and let it cool down
before removing the bowls. If a sixty or 75 watt bulb burns out before
the load is finished and the bowls are cold start with the 40 watt for
a day then move it back up one day at a time to not shock the wood.
When loading the kiln put your most stable woods the closest to the
heat. the bowls near the light will be finished before the ones near
the top are.If you want to pull out hot finished work from the bottom
wrap them in a towel so they cool slower.
This draft written 10-12-2008 and will be upgraded as needed.
I have been using these kilns for 20 years now.
