Fiddle Back Theory
charlie belden
My arborist friend brought me by three pieces of a Died Standing Dried Standing sugar maple (I think). The pieces started at the ground and up the bottom 6 feet of the tree. The bottom of the bottom piece had four piths, probably the tops of roots. When I saw that I called our turning club's Wood Whisperer (the guy is really good at visualizing what's inside chunks of wood by what he sees on the ends). This piece was about 26" tall, 27" in one dimension, 22" in the other, and there were some bumps and points on the outside indicating buds that began developing and stopped before becoming a branch. These indicate possible Birds Eye in the wood. There were also very subtle horizontal ripples going around it as well - indicating possible Fiddle Back inside.
Having halved this logette I poured water on the fresh cut faces to "pop" whatever figure was in the wood. Sure enough - Fiddle Back, with evidence of medullary rays that had begun spalting - lighter than the surrounding wood.
The Wood Whisperer explained his theory of what causes Fiddle Back figure in wood. Imagine elastic donuts with small "holes" (pith) in the center - filled with water. Stack them on top of each other. As the stack grows taller, the downward force of the weight above them on the lower donuts cause them to get flatter and bulge out - kind of like a herniated disk in a spine. The grain in each donut that was originally running up and down now has curved due to compression So when you cut "with the grain" though these areas, you cut grain paralling the cut AND acrossed the grain where the grain bulges out.
The attachement may illustrate the idea better than just words
