Turning speed
Seth poorman
Hey Guys just wanted to know if there is a better speed for wood that keeps blowing out?
Turning speed
Seth poorman
Need more information, Please...
John Kaner
Photos help. What are you turning? What speed?
How experienced are you?
Re: Turning speed *LINK*
If your talking about tearout it's not the wood or the speed. It's how sharp the tool is, whether it's scraping or cutting, and if your forcing the too to cut. You can get a clean cut in most woods at rediculously slow speeds. I get clean cuts on my spring pole lathe that only turns about 50rpm or less.
Scraping cuts generally produce more tearout than shearing cuts. Forcing a dull tool to cut also produces tearout. Use a sharp tool while rubbing the bevel in a shearing cut and then relax and let the tool do the cutting, don't force it. You should get good results.
Here is a video showing a good shearing cut.
http://www.youtube.com/watch?v=lfZsH-Xprtg
Maybe
Re: Turning speed
robo hippy
I am not sure what you mean by blowing out. If it is tear out, a very rough surface, that is from dull tools, and/or scraping cuts rather than shear/slicing cuts. If your bowls are blowing up, then it is a tool catch, and that is a technique problem, not a speed problem. Roll the tool on its side rather than having flutes straight up.
robo hippy
Re: Turning speedYou are not supposed to set it on
Terry Scott
You are not supposed to set it on fire to turn it
Sorry couldn't help myself
John has given some good advise
Ill just add get yourself some wet timer and practice rubbing the bevel with a sharp tool
If you are using any of the scraper systems you will always get tear out
