Diamond grinders: anybody regretting the purchase?
Aage Rendalen
By now a number of you have tried the diamond grinders. Do any of you feel that they deliver less than promised?
Aage Rendalen
Re: Diamond grinders: anybody regretting the purch
Doc Green
I've used my diamond wheel for three years or more and it is still going strong even though the grit is now much finer than it was when it was new. (120 grit, new)
I use it as a power hone for touching up the edges on spindle gouges, parting tools, and so forth. It is excellent for putting a small, fine burr on a scraper.
What I like about it is that it is not grabby and it generates very little heat (no sparks). Therefore, I can hand hold small items like the cutters for hollowing tools without fear that the wheel will jerk it out of my hand or it will get so hot I cannot hold it.
The wheel (WoodRiver, from Woodcraft) is not intended for removing a lot of metal, just like a hone is not a serious metal-removing tool.
When the wheel I have gets to where it no longer does the job, I'll get another one without giving it a thought.
~Doc
Dwight Rutherford
I personally think CBN wheels are far superior to anything I have used.
1. Out of the box they are balanced
2. Stay balanced forever
3. Never wear down ( don't need to be dressed)
4. Generate less heat (tools less apt to lose temper)
5. Put a great edge on the tool, ready to be used.
BTW-- Any one want to buy a used Tormek? Also have some used Norton gray wheels that I no longer need.
Re: Diamond Grind Wheels
Generally rec'd for carbide tools.
CBN's are most rec'd for M-2 and alloys up to V-15
Neither are very good for grinding/shaping, fine sharpening only.
Dennis in Southern Oregon
AAge,
Is the subject diamond or CBN wheels?
Dennis
josh bowman
God made manna for the children of Israel and diamond wheels for the woodturners. It's a wonderful thing!
Is there a difference b/t CBN and diamond?
Re: Is there a difference b/t CBN and diamond?
Ralph Lindberg
Yes
CBN is much better suited to removal of material then Diamond. Diamond can "freshen" an edge, but reshaping the chisel is nothing you should try.
CBN can every also freshen an edge.
Diamond is not as well suited for high-rpm wheels, it is easy to be, well, dumb, and wreck the wheel.
CBN is well suited.
IMO, CBN is a better investment then a diamond wheel.
Yes
As stated, a diamond wheel, with its supreme hardness, is best suited for sharpening carbide cutters and tools.
CBN does a fine job of sharpening turning tools in the upper alloys. For actually shaping a tool, go to your AlO wheel, that to the CBN to put the keen edge on.
As stated, diamond does better as a slow-speed wheel.
robo hippy
Consensus from ALL of the manufacturers of diamond and CBN wheels, diamond is for grinding carbide, ceramic and other similar type of very hard materials. CBN is for grinding hardened steel. You can grind all materials on both wheels, but they are designed for specific things.
robo hippy
Why the difference matters
David Walser
Others have answered your question: yes, there is a difference between diamond and CBN wheels. They've also shared that diamond wheels are for sharpening carbide and CBN wheels are for sharpening steel. Both are good for honing.
Allow me to try and state why CBN wheels are better for use with steel tools. (I find understanding the "why" often helps me remember the "what" and the "how".) Diamond is the hardest substance known. CBN (cubic boron nitride) is exceeded in hardness only by diamond. Since both are far harder than any steel, in theory, either should excel in sharpening steel.
Unfortunately, diamonds freely give up electrons to ferrous metals (iron and steel), causing the diamond's crystal structure to crumble. This process is sped up by heat (such as the heat generated by friction). So, while steel cannot wear away a diamond, it does cause diamonds to break down through a chemical process. While technically different than wearing the diamond away through friction, the results of this chemical process is the same -- diamond wheels do not last when used to sharpen steel. This is why turners say their diamond wheels get "finer" with use. The 120 grit-sized diamonds slowly become smaller as the diamonds give up electrons to the steel.
CBN, in contrast, does not react chemically to steel. CBN remains stable and, in theory, should last forever -- always cutting as well as it did when new.
