Does bleach damage the wood surface?
Aage Rendalen
I have experimented with two-component bleach on holly and maple to see if I could get rid of blotches that blighted the wood. While not giving me a 100 percent good result, I was impressed with the whitening effect, but I was also a bit in doubt about the 'wooley' surface that resulted. The ambrosia bowl lost its luster, and while I can still see the ripple pattern, it doesn't stand out.
My dad used to work at a farmers' co-op in Norway in the 60s and he says that caustic soda (stage 1 of the bleaching process) was used by farmers to break down the cellulose of grain stalks so that it could be fed to the cattle. I imagine that means that it will do the same to the outer layer of wood fibers in bowls, as well. What has your experience been?
