On my Delta 46-250 midi lathe the capacitor is dead and Delta cannot supply it. Does anyone know a source for these capacitors? I've tried several dealers and no one can supply a similar capacitor that will fit.
Specs: CBB60, 30uF, 300vac. 2 1/4" long by 1 5/8" dia.
Any motor repair business (the kind that re-winds motors, replaces bearings, etc.) should stock the required motor start capacitor. Have a look on-line or in the Yellow Pages (...Does anyone remember what they are?) for a motor repair business on your area and give them a call. In addition to the capacitance and voltage rating, you may also need to provide other information such as physical size, device design (position of contacts, solder-connections versus slide on connector lugs, etc.), and in some cases temperature rating. It may be useful to have the name of the capacitor manufacturer and product number (if this information is available) that can be used to cross-reference similar units made by other manufacturers.
Be sure to observe the correct polarity of the capacitor when wiring it into your motor. Should be a fairly easy fix.
You might check Graingers if you have one near by. You can search their on-line store to check the specs. Many of the new capasitor's have a impedence range instead of just one value. Here is the link to their home page: http://www.grainger.com/Grainger/wwg/start.shtml
Thanks, Al and Rob. I have visited the local motor shop, and searched several online dealers including Grainger, even Amazon and eBay, and talked to the tech guys at Delta and other capacitor dealers. Cannot find the correct specs and anything close is way too big to fit the capacitor housing. -- Bob
Hey Bob, sorry about your misfortune. Don't despair.
First, what makes you think the capacitor is bad? Did you have it checked? Nasty stuff leaking out of it? Does it get hot?
If the motor has a centrifugal switch, a defective switch can cause the same symptoms as a bad capacitor. Do/did you hear a click as the motor comes up to speed or when it slowed down?
If it's a defective switch, a motor shop should be able to help you.
Assuming the capacitor is indeed bad and you cannot find a replacement that will fit the enclosure, consider mounting a replacement capacitor outboard. It won't be as pretty, but it will get you back in operation.
I've searched Digikey, Jameco, Mouser, and etc. without finding one that will fit your case. You may be forced to go outboard. If you decide to go that route, email me directly and I'll ask a lot of questions and then make suggestions on how to do it.
I assume you have removed it and you are sure this is your problem. It is rare not to have the manufacture's name in the Cap. The most common name is Sprague but if the motor is foreign made all bets are off. You mite have a look here: http://www.mouser.com/Passive-Components/Capacitors/_/N-5g7r/
Thanks, Bob Edwards. The name on the capacitor is Shua Hua -- probably not domestic!
Doc Green, the capacitor is definitely bad--tested by local motor shop and pronounced deceased. I can start the lathe by spinning the handwheel, but that is obviously not a solution. The local shop can sell me a capacitor with the correct specs, but it is twice the length of the old one. So I would like your thinking on mounting it "outboard." My address is paula.robertibach@gmail.com
There is nothing wrong as far as function goes if you mount it differently. Of course you will want to ensure that is mounted securely, protected and any connections are well insulated.
Your capacitor is a run cap not a start cap. Also there really is no polarity on a a/c run cap. Some caps are labeled so that the guts closest to the shell are labeled so that they are wired to the neutral side of the system. When the caps short you don't get shocked by touching the frame which is grounded.
Look at the bottom of this page for CBB60 capacitors one at 25 and one at 40 for 300 volt. Not sure how yours could be packaged smaller than the 60 mm for the 25 if yours is 30uF.
