Resp-O-Rator
Resp-O-Rator
Resp-O-Rator
Clyde Collier
I had a bad reaction to Mesquite sanding dust and I wonder if anyone has any experience with the this snorkel like dust filter?
Re: Resp-O-Rator
Brad Vietje
Re: Resp-O-Rator
Brad Vietje
Hey Clyde,
I have one, and use it for sanding operations. I've added a layer of paper towel as a pre-filter, held on with rubber bands, so I don't have to change/clean the primary filter as often. Works well for dust; no evidence about allergies or other health concerns.
Breathing through your mouth causes a fair amount of condensation in the air exhalation tube at the bottom front -- especially in winter if you turn in a cool shop. This "condensate" is tends to drip onto your hands, tools, or lathe if you are standing over your work -- which is probably a sign that you're standing in the firing line, anyway. Turners with a large diameter neck might find the unit coming apart, but it would be really easy to adapt the thing for the mega-necked ex-football types with a bit of tubing and barbed hose connections from the hardware store.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Resp-O-Rator
Re: Resp-O-Rator
Have one. Comfortable but the nose clip is mostly worthless. Good for dust. Can be used with most face shields so it won't fog up the visor. Ixnay for vapors.
Re: Resp-O-Rator
Bill Blasic
Re: Resp-O-Rator
Bill Blasic
Clyde,
The Resp-O-Rator works extremely well to keep dust at bay. I have had no problem using the nose clip. As mentioned it fits under the face mask without a problem. If you want to protect your lungs it is a great investment.
Re: Resp-O-Rator
Re: Resp-O-Rator
Barry L Elder
Haven't used the one you speak of, but there are many half-masks out there by various makers with better filtration for around $15. I use a 3M 6200 series and have for many years.
Re: Resp-O-Rator
Re: Resp-O-Rator
I much prefer the half masks. The only time I put something like that in my mouth is when I'm snorkling.
Re: Resp-O-Rator
Bob Moffett
Re: Resp-O-Rator
Bob Moffett
I have been using one for several years and like it very much. I have a reaction to Cocobola and if I wear my Resp-O-Rator, I have no reaction. I'm not sure of the actual number but, I think if fliters down to 1/2 micron or something like that. I also like the light weight feature. I don't have any financial interest in them, just a satisfied customer.
