routed ornament
I did this along with my new mirror to show routed details in my Demo in Athens Ga on monday evening.
routed ornament
Re: routed ornament
Philip Duffy
Way toooo awsome, John! pHIL
What Phil Said x2!
When you turn finials...
... do you work from a full-sized drawing, or do you just follow your eye and create the shapes and proportions as you go?
Re: routed ornament
Jim Rutten
Your repeated shape of the main body down at the end of the finial is perfect.
Re: When you turn finials...
Ellis I occasionally do a drawing but this particular style I've done so many times I just play and try to improve the lines on each one. Sometimes I nail it and sometimes I don't. I haven't made on in a while so I was a little weak on some of the details that I try to achieve.
The fun things that are such small details are things line do the curves at the top of each vase shape match. difficult to do. I also try to make the top vase longer than the bottom one. I try to make the saucer in between them the proper size. Not too large or small. Working on the cove on the top it's fun to play with the negative space. Sometimes I go for a perfect sphere space but most of the times it's a modification of the Frank Lloyd Wright tapered column.
I have a tendency to make my icicles too long. If I draw them out in advance I don't do that as often.
Re: routed ornament
JIm I often add a detail at the bottom and top of the ornament that will sometimes mimic the shape of the main ball or some detail in the ball. I think it helps pull the whole icicle together.
