I hate waiting for glue to dry.
So naturally a lot of multi tasking takes place in my shop. Some of these pieces take 4 or 5 seperate glue ups so I rotate them out. While one is drying I'm cutting the slots in another one and gluing up another section. If all of them are occupied I turn things that don't need glue up. At least until the glued pieces are dry and then I start another step on those.
Re: I hate waiting for glue to dry.
john Veerkamp
How long do you wait from glue up to turning or making additional cuts. Assuming you use regular yellow glue? I'm always afraid to do less than 24 hours?
Depends on what I'm doing. For gluing inserts into the wood like the Walnut mirror blank on the bottom, about 20 minutes will do. I've had occasional failures when waiting that short of a period. I usually give it 30 or more.
If I'm going flat wood to flat wood such as the finished side of inside out turning I wait an hour or more.
If I'm gluing up table legs or flat work like the mirror with veneer in it I wait over night.
Now here is the problem. It usually not the glue, it's the glue joint. If your joint is really flat then the glue holds after it cures for about an hour. The problem is there is moisture introduced in the glue joint. So you turn the piece down and sand it. The moisture creeps out of the wood and the wood shrinks and the glue doesn't so now you have a proud glue line. That really hasn't been a problem for me on my mirrors but on segmented work or really complicated glue ups it does show up. For those I try to wait several days before final sanding if I can and will sometimes turn them over a period of days to reduce that problem.
Paper joints are also a problem. I find that I have to wait a minimum of 1 hour for a paper joint to dry before turning. If it's larger than a Christmas ornament or some other small turning I wait over night for paper joints to dry.
At Least
You're not standing there watching it. :D
Re: At Least
No I'm on the computer answering questions about the glue ups. :)
Steven Antonucci
It's like watching paint dry, only less colorful
Mike Stafford
Watch the grass for a while....
With all the rain we've been .......
JamieDonaldson
....receiving, you can just about see the grass growing! I would like to be able to see the mower cutting the grass while I watch, but that's not happening, and we had another 1.9" this morning.
One piece from the glue ups
I did this piece to show how the different router bit profiles affect the shapes of the added contrasting wood once you start turning into that shape. If you take the rectangular piece as 12 oclock, it was done with a straight router bit. A flat piece of wood was glued into this groove.
1 and 2 oclock were done with a 90 degree V bit or in this case a straight cutter mounted at 45 degrees so the 90 degree corner did the cutting. A Square "dowel" was glued in this groove.
The 3 oclock position was a ball end cutter with a dowel glued in the curve.
You can see how the shapes of the router bit affects the design of the contrasting piece as you cut through it or as viewed from the end.
This also shows some of the problems and design opportunities. If you look closely at the 12 oclock piece you will see that there is a slightly larger glue line on one side. It's very difficult to get a router bit to track perfectly straight when presented to the wood in a groove cutting orientation. Normally on flat work I will make 2 cuts so the cutter is cutting in a clockwise direction and gives a straight line. In this case it was one cut and the cutter wants to follow the grain if it can.
The other thing to notice is they appear to be stacked on top of one another. You can eliminate this to some degree by cutting 90 degree mitered points on the ends so they run together. That is quite challenging to do especially with the round dowel. It also leaves a gap in the dead center that must be addressed or covered up. Just something to think about when you do these things.
