i never took geometry - math help
Darrin Hill
ADHD people cant do math.. it's why i got married... at least the top 10...
especially liberal arts majors with adhd.
trying to cut the staves for the top of a birdhouse.
trying to figure a formula for the # of staves to get how much of a degree to cut a circle to get an even number of pie wedges.. ie i want 24 pie slices.
and also how to figure the cut on the sides to fit them all into a pyramid.
i can take pretty photos but cant do math.. tried looking on the internet and didnt know what i was looking for..
any help is appreciated...
Re: i never took geometry - math help
that makes 2 of us *LINK*
Bridge city tools sells a simply pamphlet that has all the math done for you. You simply decide how many sides you want and angle you want the pieces to rise and you can look up the math in an easy to chart that tells you exactly what angles to set the saw and miter gauge.
If you will tell me what angle you would like the roof I'll look it up in my book.
http://www.bridgecitytools.com/default/other-products/books-1/woodworker-s-guide-to-compound-miters.html
I Took Geometry...75 years ago....
Wally studied with Euclid
I thought he WAS euclid..
Re: that makes 2 of us
Darrin Hill
basically...
a 8.5 inch diameter cone.....
the question is...
if the longer the piece, i would guess the miter cut on the sides wouldnt change?
and 360 / # of segments (say 20 ) = 18 /2 = 9 degrees... but its the cut for the staves im a bit confused.. cause if i wanted a taller peak, would the miter cut change?
but lets just say i want 12 pyramid staves... bout 7-8 inches long.. 8.5 diameter at base...
Stuart Johnson
Darrin, It sounds like you want to cut compound staves. You'll need to cut both the miter angle and tilt your tablesaw blade. For example an 8 inch base with a 1 inch top (outside measurements) would be a 35 degree slope. For 12 staves the miter angle is 12.38 and the blade tilt is 8.54.
Send me your actual measurements and I'll see what I can produce.
Re: i never took geometry - math help *LINK*
Mike Brazeau
I have a tutorial for a compound staved roofed birdhouse at www.ghwg.ca in the Techniques section. I used the site at the link below to do my initial calculations for 8 compound staves. I would really recommend using fewer staves than you have stated. Doing a glueup with that many staves is going to be a real task.
Miter Calculator
Darrin Hill
ok.. well. last year i had a bunch of pine ... so i made about 10 cylinders.... all are about 6.5 inches diameter...
and according to theory i was following mikes instructions... to the letter...
none are the same length, but that doesnt matter to me...
so i figured about an inch overlap at the bottom... 8.5 ish inches diameter and they could go all the way to the top without a finial... but either way.. finial or not..
so the base is 8.5 inches or so.....im figuring the staves would be about 7 inches long too... or less.. depends on the angle of the top..
just make me happy and gimme numbers...
d
Darrin Hill
um.. actually... when i did the original cylinders, i got your info off of woodturningonline and followed the instructions to the letter...
I got an oval based pyramid.
Re: I Took Geometry...75 years ago....
Curt Stivison
Wally probaly knows how to use a slide rule too.
Darrin Hill
so what do i need to do? i'm pretty much at a standstill until i get some measurements.
I could try mikes thing but as i said, i used a set of instructions and got an oval instead of a circle. I know i did something wrong, but..
I have to use my tablesaw and i have no jigs.. just a miter gauge and a fence.
I can set the miter at an angle.. i can set the blade at an angle,... but thats bout it..
Stuart Johnson
Eight staves.
1/2 inch board 7-7/8 inch wide.
miter angle: 11.7
blade angle : 19.35
lower outside 8 1/2 inches
upper outside 1 inch.. (turn a finial to top off)
Glue up in pairs, then two pairs, do any adjusting so the two sets of four meet flush and glue together.
I would build one out of plywood first to see the end result before using anything good.
Darrin Hill
awesome..
gonna use 3/4 pine... got tons of scrap...
will that change anything? cause i wanna turn em round...
Stuart Johnson
The measurement is outside so 3/4 shouldn't be a problem for the lower end. I'm not sure about the 1 inch outside upper and the inside area but the angles will be the same. I forgot to include the edge (widest end of the lower end) is 3-1/2 inches.
