Anyone else recall an article, I believe in the AAW about laying out the thread pattern on a baseball? I swear I saw an article that helped you size and get it to look good but can't locate the article now. Thanks
Randy, you can research topics or authors in an online index of journal articles. It's in the Members' Area on AAW's website (you have to login to that area). The index is fairly comprehensive. From there, go to the issue listed in the index.
The article on turning baseballs is in volume 20, issue number 1 (spring), 2005. The image on the cover is of a large natural-edge burl platter, probably maple. The banner across the top is blue.
Hint: Turn a sphere to the size of a baseball, then take a regular baseball and cut the outside leather off right down the middle of the threads. You can then lay that piece of leather over the top of your sphere, and it will give you the exact orientation and thread layout you need. (There are 88 sets of stitches.)
That's how Norris White did it. And he hollowed it through a hole that he later plugged with what looked like a manufacturer's label so there was no visible entry. He did the set of balls, caps, catcher's mit, mask and bat featured at the Louisville symposium several years back.
That is what I did, went a got a baseball and cut the cover of to get the spacing. But I took it a step further. Since my sphere and the baseball were no exactly the same size, I used the printer here at the house and kept enlarging the leather cover by 1% till I got it exactly correct. This was actually pretty easy to do. I think it ended up at an additional 4%.
