router mount for lathe
bob davis
friend wants to mount router ton lathe..where can he find lucas info??
Re: router mount for lathe
tell him to write me
I have some photos and maybe some handouts but will have to dig a little to find them. Getting ready to do a demo on routing on the lathe in Athens, Ga the end of this month. If he'll send me an e-mail I'll try to answer.
I just finished using the same jig but with a dremel to make a candlestick drill out of a spade bit. I ground it by hand as accurately as I could to maked lines and it just didn't cut clean. It chattered which told me the sides weren't equally ground. I decided to rig up a way to do that. I used my banjo mounted router table platform and my Dremel that was mounted in a carriage. Then I used an index wheel to index the drill bit slightly off flat to give the drill edge some relief so that it would cut clean. Then used a grinder bit in the dremel to dress the hand grind so that it would cut clean and both sides be the same distance from the center and the same angle. It worked fantastic. I'll be putting together an article on this shortly.
Slick!
Tony - Memphis
That gives me some ideas about some other shop tasks. I made a setup to route tenons in a table spindle off the lathe. Used something similar to scratch reeds in some table "handles."
I think I have that same degree wheel. It is a nice piece. Seems like I have a similar version in plastic too? It was good, but Ilike the Al model better.
Tony
Alan Zenreich
Alan Zenreich
My take on mounting a small router on my lathe is a bit different.
Perhaps it would be useful to some folks.
I've replaced the hollow steel post on a Dremel drill press with a solid rod of aluminum and tapped a hole for a modular tool post.
This lets me position the Dremel in any orientation, angle of cut, height, and still retains the full drill press features, for example, stops to control depth of cut.
Re: tell him to write me
Dick Woodhouse
Hi,
You sound like the guy I would love to get some info from. I have been thinking for a number of years that I would would like to attach the router to my lathe and turn some colums and adding fluting to them. But, I have never seen a plan to a.) hold the router leval B.) move the router left and right C.) Move the router in and out as needed. If I could get the hand-out that you are speaking of I think that it would be most interesting. And could be everything I need to know to compleat this project that is in my mind.
Is there anything that you need from me?
Thank you for your assistance.
Dick Woodhouse
KC Woodturners
Jeff Salter *LINK*
jeff willaford
has a pretty complete approach to using a router on turnings. You might want to take a look at his website. Just a thought.
http://www.jeffsturnedwood.com/
Alan, it looks like
Jim H
You have a long tether on your control panel. If so, is it an extension, or did you replace the ribbon cable? Any additional info would be appreciated.
Alan Zenreich
Re: Alan, it looks like
Alan Zenreich
Jim,
For a short while, I experimented with using a longer ribbon cable to reposition my panel. It worked ok, but I didn't move the panel much.
Fortunately Nova then came out with the wireless remote control for the DVR XP and I switched to that system.
Jim H
Thanks, I have the remote, and it works well enough to be functional. I was thinking it would be nice to have all of the features of the main panel without crossing the line of fire.
Randy Gleckler
I might have to see about having you do this Demo over at our club, I've been watching these with interest. If you find those notes, could you shoot me a copy? Thanks John
