I'm looking for a female audio jack that is solder-able in order to make a replacement cord for my Burnmaster woodburner. I've looked at several places locally including Radio Shack and on line and am coming up empty. Any ideas where I can find these? I'm on my fourth cord from the manufacture and I've come to the conclusion that the connections where the wire is soldered (or maybe not) comes loose and makes an intermittent connection. So I figure I'll make my own. At least when my come loose I can fix them and they won't cost me $20 a pop! I've got the male connectors now I just need the females. Thanks for any help on this one!
Jen
Pardon the hideous photo. The connector I need is the one in the middle. The connector on the left is the male and the wire on the right is what I'm using to make the new ones. It's heavy duty gauge speaker wire that Graeme Priddle recommended. It's what he uses so I figure he knows what he's doing.
They only have 1,700 in stock for $ 1.03 each, so you better hurry!
The kicker is that they apparently have a minimum $ 20.00 freight charge - I don't know how that relates to small orders, but you could call them and ask what their policy is. (For example, it seems ridiculous to charge $ 20 for <$10 worth of parts....)
Good luck replacing your in-line female RCAs - I have done a fair number of these before (I was an engineer at a FM radio station while in college) - just watch the fit between the cord and the contact cover - sometimes these get a bit "tight", especially if you over-hear the solder joint and add too much solder.
In the search box, type "plugs and jacks". The RCA jacks begin on the second page of the listing.
If you use the panel mount jacks, heat shrink tubing applied over the jack and soldered part makes for a neat installation. I think Radio Shack may have assortments, or you can order it from Jameco as well.
Thanks Everybody! Well I found a source via another source that you guys posted yesterday and placed an order for 6 of them. I wanted metal cased ones and found them at a place called Summit Source. They were a dollar and some change and the shipping was only $5 compared to some places that had a huge shipping fee. I'll let you know how they work out.
...RCA female socket, so solder the leads well and than slide a short length of heat shrink tube over the connections and heat seal. When the metal cover is replaced, the heat shrink tube should stick out the back about an inch up the wire. Then completely seal the metal cover with heat shrink tube, and you will have a much more durable and safer connection that won't easily twist off the solder connections in heavy use. I'm surprised that type of low voltage connector is used in the first place, and with that exposed metal cover on your replacement you create a serious shock hazard! An insulated socket like the original would be much safer, and I have several exactly like Rob referenced in my electronics stash if you want one. It is a standard stock item at Radio Shacks and I'm surprised they were out of stock, so I can make you such a deal!.(;-D)
Radio Shack should have been able to order the connectors if they did not have in stock. I have used them but the strain relief is too small for heavier speaker wires. The second web site has some that look like they would take larger wire.
I would worry too on the all metal unless you are using without the shield as second electrical connection.
