THE WOODRAT IS BACK!
Powermatic 90 tailstock dissassembly *LINK*
I am in charge of getting the high school lathes working so the kids can use them. I have a Powermatic model 90 tailstock that won't work. The quill is frozen. I'm trying to get it apart. So far failing. I'm soaking the parts I can get to in penetrating oil. I downloaded the manual. I was hoping I could get the quill and it's drive screw out of the body of the tailstock so I can soak those threads in penetrant to make it move so I can get it apart and clean the threads. It won't come out of the body without more force than I want to apply and I can't get the rear screw in piece off either.
does anyone know if the quill with the drive screw in it will come out through the front or is it essential to remove the rear guide piece of casting. The part I'm talking about is part no 45 that is right in front of the handwheel. Part 44 is the drive screw that moves the quill in and out.
http://vintagemachinery.org/pubs/detail.aspx?id=4332
Re: Powermatic 90 tailstock dissassembly *LINK*
Lloyd in Mississauga
John,
Can you take the entire tail stock and flip it upside down in a bucket of thinned oil to see if the fluid would work its way in a bit to help?
It looks like the bearing (90-146) may go on the shaft and then your 90-145 to house the bearing and then the key (90-147) go in and fits into the hand screw to help it turn the thread.
If that is the case, then 90-144 will not come out through the front without removing the key to allow the bearing housing to come off. The outside of the bearing may be seizes into the nut housing (90-145).
If you can apply a bit of heat to the nut housing and them tap the end of the threaded shaft to try and drive it forwards, you may be able to get it out. tapping on the hot nut may also help loosen the bearing if it is rusted in there.
Good luck.
Lloyd
Yea that's what I kind of thought. This was missing the key which is why it wouldn't turn in the first place. I worried that the key was broken out because the bolt was locked up in the quill to begin with. I'll just keep soaking everything in penetrating oil. I have patience. It once took me almost 2 years to free up an antique 25 caliber pistol. I'm sure this won't take that long. Heat and cold often helps the penetrant get into the tiniest places.
got the big screw in plate off and was able to get the quill out. Now I'm working on the drive screw. What they call a bearing looks like a sort of curved side washer. Only part of it was left, the rest is broken and missing. you can see what appears to be a bearing surface on the bottom of this bolt next to the quill. I'll call and see if it's possible to order that part. If not I guess I'll be trying to build one. I have to mill out the old key way slot and build a new key also. Glad it didn't take 2 years. :) I was making 2 mirrors and everytime I had to stop I put some more penetrant on and tried to pry things loose.
John, kerosene make a very good .......
JamieDonaldson
... penetrating solvent for such applications, at a fraction of the cost of most other solutions.
Got it all apart.  Now need to order the bearing
