making pens WITHOUT KITS!!
Gordon Patnude
Gordon Patnude
I'm looking for any information available about making pens without kits. I've made about 60 or 70 different pens, mostly for gifts, but I've also sold quite a few, so I'm not a total newbie. I recently joined a turning group and our president issued a challenge for the meeting in August: TURN a pen without a kit.
Now that just doesn't make any sense to me -- where do the innards [mechanism, tip, clip] come from???
Where do I start with this???
Has anyone done this before??
Help!!!
Re: making pens WITHOUT KITS!!
Dan Jechura
Dan Jechura
A while back someone told me about a 33 cent pen. I would have to go look him up. He bought pens at the dollar store 10 for a buck. cut off the plastic so all he had left was the tip and innards. drilled a hole in the center of the wood. I think 3/32 inch and turned the wood. Then glued the pen in to the wood. Or something like that. I've bought the pens but never tried it yet.
Dan J.
dick gerard
Those are commonly called stick pens. There is no mechanism. You pull the refill out of a Bic pen. Drill and turn the blank. 3/32 inch ho;e a bit deeper than the length of the refill. Use a drop of hot bees wax on the ferrule of the refill to hold the ink in place. The only problem is that you can't carry it in a shirt pocket! Made and sold literally thousands of them back in the 80s and 90s.
Rob Wallace
Rob Wallace
In a hands-on class with Bonnie Klein we made a little project she calls a 'stick-pen' - using the ink/ballpoint unit from an inexpensive Bic pen (easily pulled-out of the plastic body with a set of pliers), you drill-out the barrel and insert the ink/ballpoint into the new turned wooden body. In the class she demonstrates making "carrot" pens (colored orange with felt-tip pens), but since back then I was a Little League coach, I turned my pen body into a baseball bat. Dennis Daudelin has an on-line tutorial for making these at: http://www.woodturningonline.com/assets/turning_articles/Baseball%20bat%20pen/baseball_bat_pen.html
These pens are quick and easy to make. No mandrel, bushings, kits, etc. are needed, just a long drill bit and a way to drill straight holes through the blank (Bonnie used a special guide that fit into the tailstock of the mini-lathe that enabled drilling with a 12" long bit, 5/32" diameter, but check that - my memory is not clear on the size needed).
Kurt Hertzog also has a web page explaining stick pens at: http://kurthertzog.com/articles/stickpen/stickpen.htm
If you want to turn inexpensive pens without needing kits, these are the way to go. They are good for demos, particularly if you pre-drill the main hole in the blanks in advance. All you need to do is turn, sand, finish, and insert the ink/ballpoint and you're done!
Hope this helps,
Rob Wallace
That's the stone age version...
Dick Coers
...but as mentioned, do a search for kitess on the IAP. There are real artisans with pens there. Guys that cut their own multi start threads and parts. Often with a high quality German quill. Absolutely nothing like a Bic and stick. Actually an insult to a serious kitless pen turner.
Gordon Patnude
Re: That's the stone age version...
Gordon Patnude
Thanks for all your help. At this point I have a better idea of the process and methods. It appears to be a little more complex than I expected, but not impossible.
Terry Scott
Go to www.sawg.nz.org in the projects is a simple pen with no kit all you need is a refill
A 3.5mm drill bit a 4mm drill bit and a rivet
Cheers
Bill Blasic
Bill Blasic
Terry,
Think it should read:
http://www.sawg.org.nz/
Bill
Terry Scott
thanks Bill
Mike Brazeau
A couple of years ago while browsing back issues of the AWT on the AAW site I came across an article by J. Paul Fennell on making these pens. September 1989 issue, Pages 8&9.
