Sources for truckloads of whole logs
Devon Palmer
Hey All,
If I wanted to buy truckloads, or even a 1/2 semi load of hardwood logs to bust down into bowl blanks in Central Ohio, any idea where I would even begin to look?
Re: Sources for truckloads of whole logs
Dick Hines
Dick Hines
Check with some local tree guys. Some times they will bring you logs if they are working close. I have a guy that brings me some logs when he gets a good one...cherry maple,walnut, holly and so on.
Best part his he only wants a bowl or two with each load.
TomCollins
If you contact the Ohio Division of Forestry they can send you a list of loggers who work in your area. You may be able to get them to deliver a load of logs(for a price). I believe there is also a sawmill directory available which would list sawmills in your area. They may be willing to sell some of their logs but you would have to figure out transportation. You can check ODF's website for contact numbers.
TomC
Joe Herrmann
Doll Lumber (a local sawmill/lumber dealer in Champion, OH) sells log cut-off by the pick-up load fairly cheap. You might check with some local mills in your area to see if they do the same.
bill Crommett
Years ago I bought a semi load of logs from a fellow that advertised logs for firewood to be used in outdoor furnaces.
