Veritas - Innovation in Tools
more AAW symposium stuff
There were 2 new booths this year. Both selling sphere turning jigs. http://www.chefwarekits.com/woodturning-thread-cutting-and-wood-ball-jigs
Craig had both threading and sphere turning jigs plus a bunch of very fun kits for woodturners to make products for selling and gifts. Nice products and the prices are good.
http://www.sphereturning.com/ Probably the best sphere turning jig on the market. I'll be able to tell you more in a month or so. One of my best friends bought one and I'll be able to play with it shortly. I did watch the demo several times and observed my friend learning to work with it before she bought it. This thing leaves a great finish and is very very easy to use. Price is not cheap but the neither is quality at this level. It will also hollow the sphere very precisely if you make it in 2 parts.
http://www.davidnittmann.com/airbrush.php I am very impressed with these air brushes and compressor. I drooled over them in Arizona. I found an unbelievably good deal on an Iwata with compressor or I would own one of David's now. The compressor is very quiet and small the air brush seems excellent. Certainly beyond my skill level.
http://www.rjrstudios.com/ I didn't buy one at the show but will probably order one when some more money comes my way. I think the sanding mops will greatly increase my production of some of my mirror handles and footed bowls. Stephen Hogbin was discussing how he sands his cut apart pieces for accuracy before re assembling them. He thought the sandflee drum sander might speed up this process. If someone has one, let us know what you think. I've always wondered if it would work for sanding segmented rings.
Re: more AAW symposium stuff
Alan Zenreich
Alan Zenreich
I've had a 9" Sand-Flee for a few years, and use it a lot. Great tool.
I also use the sanding mops. I am very happy with them.
Maurice McLeod
John-I was curious as to what a sanding mop is and went to the website you gave the link for. Could you give a brief description of how they are used?
Thanks.
They are used to sand rounded or odd shapes that are difficult or slow to sand by hand. You can use them in a drill press and hold the work piece or in a flex shaft. When I do my odd shaped handles it takes forever to hand sand them. I can sand some parts using an oscillating drum sander and some parts on a disc sander but the more carved shapes are really tedious hand sanding. The sanding mop should speed that up but I'm a little concerned it will leave bumps where knots or hard spots in the wood are. I suppose with careful carving before hand you can start sanding with the mops in a higher grit and avoid some of this problem
dick gerard
What size sanding mops do you use? What grits?
Dick I'm still looking. Don't have any now but I'm looking mainly at the 2" since most of my carving projects are small. I think if I can start no courser than 120 grit I won't sand bumps in quite as bad however finer might be better. I'll probably try one since they are kind of expensive and see what it does. Maybe 180 grit. Since I'll be power sanding it will remove wood fairly fast. That grit should tell me whether I need courser or finer.
I start the carving on these handles with the bandsaw and then switch to either rotary carvers or wood rasps. Then if I can I use small sanding drums in my flex shaft to clean up what I can with those followed by hand sanding.
I'm hoping that the mop will let me clean up the rasp marks faster. I don't mind hand sanding once I get to 180 or 220 but it's the first part of getting rid of the rotarty tool marks or file marks.
Alan Zenreich
Alan Zenreich
I use four 4 inch "double" sanding mops. 120, 180, 220, and 320 grits. They are a pleasure to work with.
