AAW symposium
AAW symposium
AAW symposium
Over the next few days I will try to put together some of the things I learned or saw at the symposium. I'll be a little slow with this as I have other commitments to take care of.
I didn't take an accurate count but there were at least 4 or 5 dealers selling the CBN wheels. I can certainly understand why, I love mine. Sorby had their sanding sharpener. Expensive but certainly does a good job. Tormek was there of course. I didn't see any other sharpening systems.
Johannes Michelson had his sharpening system and so did Stewart Batty. I really like the Michelson fixture for positioning the tool in the sharpening jig. Stewarts tool rest is solid as a rock and easily positioned. I'm real happy with my Robbo Rest which does the same thing. Stewarts rest in infinitely positionable and solid as a rock but is a lot more expensive than the Robbo rest.
There were 2 new chucks. The Nova infinity is called the game changer. It has instant release jaws similar to the Easywoodtools chuck but the big advantage is your old Nova chucks can be converted. You buy a new set of inner jaws and all of the new quick remove inserts will fit your old chuck. You can also buy the replacement inserts to fit your old jaws so they can all be converted to the new system. It's very fast and easy to change jaws. I think the whole new chuck with a set of jaws ran about $400. I didn't price the inserts or quick release couplers. If you own a Nova chuck I would look into this.
The other chucks were from www.chucksplus.com His chucks look a lot like the Vicmarc chucks and will even take the Vicmarc jaws. Very well built with titanium coating on the jaws to resist rust. They have 4 different sizes from very small to really massive. I bought the small one which is perfect for mini lathes. Even the small one will take 4" jaws. They use a 10mm hex key like Vicmarc does. The pricing is very good which is why I ended up with another chuck (like I need more)
Robust lathes had Andre Martel in their booth selling some very nice calipers for measuring wall thickness. Wish I had purchased one but just didn't think about it until too late. The Robust lathes are really just spectacular. That's about all I can say about them. Everything works with ease and precision. If I upgrade they will certainly be on the top end of my list.
The new Jet 12" mini is massive. 137lbs and solid as a rock. If you are thinking of upgrading to a larger mini this needs to be on your list of possibilities. Everything works smoothly and with precision and the mass of the lathe will handle some pretty good out of balance pieces.
Well there will be more to come as I get time. don't want to make this 40 pages long.
Re: AAW symposium
Steven Antonucci
Looks like another $200 per chuck/jaws
steven antonucci
I looked at the Nova Infinity info on the Teknatool site, and it's going to be just about $200 for the quick swap option. I want to say the SN2 bodies are about $150?
I think I'd rather have 2 bodies than jaw swapping capabilities? Scratching my head on this whole concept?
Steve
Re: AAW symposium
Re: Swap Meet
I have 2 chucks and 4 sets of jaws; large and medium DT, long-nose, and HDPE shop-made. Changing jaws with the 8 screws (hoping against hope not to drop one in the shavings) can be a pain. I do try to anticipate what I'll need for a particular piece, but that still involves changing jaws. I can see where the quick-change option could be popular, especially in a production shop setting. However, for $200 I'll stick with the screws; I do have spares after all ;)
Re: AAW symposium
Re: Swap Meet
chucksplus claimed their jaws will swap out with Vicmarc. May have to take them up on that claim. I'll let you know what I find out.
Re: AAW symposium
Arbortec Turbo plane *LINK*
Got to see it in action. Smooth cutting and safer than the regular cutter. won't cut on the edge so if you need that option for your shapes it won't work. for planing and smoothing cuts it's excellent. It is resharpenable. Cost is a bit prohibitive unless your making money with those turnings. Then the time savings by reduced sanding would come into play. Looks like it would be great for changing the shapes of bowls, or large flutes. Definitely good for shaping larger gentle curves.
http://www.arbortech-turboplane.com/
Re: AAW symposium
VM120's
How'd you know that? Been peekin' in my shop window? :D
Re: AAW symposium
Dick Hines
Re: Swap Meet
Dick Hines
I have 6 Nova chucks, 7 if I count the one that came with my Mini. The one that tales 3 hands to mount a bowl.
So at $200 each it would run me $1200 just to change jaws. I think I will sit this dance out.
Re: AAW symposium
Re: Arbortec Turbo plane
Steve Worcester.
Looks like it works well, but those things scare me.
Re: AAW symposium
Steven Antonucci
If you use them right, you can't even feel it
steven antonucci
I have the old "chainsaw" disc and the newer silver gritty disc... when presented correctly, they just erase wood. Wrongly, it's a wild ride.
Little bit of a learning curve, but they aren't so bad once you get it.
S
Re: AAW symposium
Re: AAW symposium
dick gerard
Here's another option:
Buy an Axminster chuck through Lee valley. Axminster will sell you a separate set of slides for each jaw set. That way when you want/need to change jaws, just wind 'em out and wind the new ones in. Slam duck. Craft Supplies used to sell the slides for the Nova chucks (I purchased a few sets), but no longer. I just wish OneWay and others wou;d do the same. No more screwing around with screws!
Re: AAW symposium
Bob Moffett
Re: AAW symposium
Bob Moffett
Does anyone know how many people paid to attend the AAW Symposium?
Re: AAW symposium
John lucas
Any of these tools used flat like the planer blade are very controllable if you use both hands. If you use any of them in a position that resembles cutting with the nose of a chainsaw the. They can grab and run on you
Re: AAW symposium
Re: AAW symposium
John lucas
I thought I heard a number over 1200
Re: AAW symposium
Rob Wallace
Correct.....
Rob Wallace
I haven't seen the final data yet, but there were about 1,200 advance registrants (as of June 24th), with several on-site and one-day registrations added to that (~100). We also tried assessing 'free' attendance at the Instant Gallery and Trade Show from the general public, but that is quite difficult....perhaps a bit more challenging than hearding cats. The Symposium was advertized locally, and Rudy Lopez and crew had a turning demo set up at the Tampa airport, on which a local television station did a segment lasting about 3 minutes that aired on local TV news.
We do know that some of the on-site registrations and one-day registrants came from Florida and from several neighboring states (Georgia, Alabama) and a few as far away as Louisiana and Kentucky.
We had lots of first-timers to an AAW Symposium (which is not unusual), but had several from England, New Zealand, and China, among others from closer locations. After the banquet and on Sunday morning, many attendees said they had a great time and were "totally immersed" in turning, and were ready to get back to their own lathes and try what they learned! One guy told me point-blank that he concluded he'd wasted the past few years of NOT going to the AAW symposium, now that he saw what they are really like. He is already on-board with going to Phoenix next year!
It was great meeting so many people who all share the love and passion for woodturning. Although we received some comments of disappointment that there weren't as many attendees as in some previous symposia, many of the vendors I spoke with said that they had a very successful time in Tampa. This suggests people were buying tools and supplies and things are turning around. (The same could not be said for the 2009 and 2010 symposia.)
Rob Wallace
