Tool rest height
Tool rest height
Jack Guzman from Maine
Tool rest height
I'm building a 24" wooden tool rest for chair leg turning for my jet lathe. I got the idea from a blog by a chairmaker named Tim Manney. I am attaching a piece of round bar stock 5/16" in diameter on the top edge of the bevelled rest.Before I glue this on I'd like to be sure of the height.This will not be adjustable. As all I plan on using this rest for is chair legs It should never need adjustment. What height should I have this.As of right now the top edge of the bar is about 1/8" below the center. The rest will slide in or out.The only tools I use are a skew,roughing gouge and parting tool. I never scrape. Where should I set the height?---Jack
Re: Tool rest height
I set the height so my skew cuts on the upper 3rd or even higher for turning spindles. For cutting coves with spindle gouge I will sometimes lower it but for mass production I tend to find a height that is comfortable for me with my back straight and the tool on my hip for better control. So I look at the where the tool is cutting and where it is positioned on my body and the tool rest goes on the line between the two. This may or may not be on the center line of the work depending on the two factors mentioned above.
Another factor is how far you like the tool rest from the work piece. Some tools have a longer bevel than others and you can't have to tool rest really close because the tool bevel will be on the tool rest which can fight you. The parting tool is a good example.
So for mass producing spindles I tend to have the tool rest a little higher than center line and a little further away from the spindle. But again this is based on the height of my lathe, how tall I am, how I hold the tools and where I like them to cut.
Rob Wallace
What John said.....
Rob Wallace
....is pretty much the same advice from here.
The cutting edge of the tool with gouges and scrapers at or slightly above center-line, and skews up at about the 10 o'clock position. BTW - it is also helpful to incorporate a ruler or other measuring device (or just evenly-spaced marks) right into the tool rest design to help with locating major element positions, etc. (It's certainly not necessary, but it is very convenient...)
Even if it takes some additional effort to make it adjustable, the tool rest will have more versatility beyond the present job at hand, making it more valuable to you in the future. Just something to consider.
Good luck with your project!
Rob
Dick Coers
It will be a real compromise to not have adjustability. Unless you are making long tapers, I don't see a really great advantage to the long rest on chair legs. Most legs are broken up into sections that are seperated by some turned details. This allows moving the rest to either side of the details. I'm thinking about windsor chair legs here. You may want to turn all the legs with the roughing gouge with the rest at one height, then turn them all with the details at a different height. But still I would be at a different height for skews and detail gouges. I have seen production turners that use a real flat continental style gouge for almost an entire spindle, so I guess the design may dictate the success of your rest.
I end-grain hollow so, when establishing the shape of the piece, I'm essentially spindle turning. I have taken to positioning my rest above center, about at 10:30 to use my big skew to refine the profile. I find I get more control with less effort this way and with the tool held on the horizontal to channel the down-force into the tool rest.
Dennis in Southern Oregon
It seems to me that you could best satisfy yourself by running some experiments with your existing tool rests.
Dennis
answers
Reading the responses I'm starting to understand why there are no definitive answers to this question . It is a relative thing. I am short ,5'4" ,so my approach to the lathe is relatively low. What always seems to work for me is slightly below center.So I will build this rest at that height. I have a 10" rest that came with the lathe. When I turn a leg I need to move this several times just to get a rough cylinder .I work with rough maple blanks riven from a log with the sharp edges removed by drawknife. Also vibration is always an issue with this method. I find when using a wooden rest I get less vibration.
I build windsor chairs so I turn alot of legs. What I'm trying to do is to take some of the difficulty from this operation. My results keep getting better but I need to get my tools working at their most efficient so I can concentrate on technique.
Thanks for all the helpful input.---Jack
Re: answers
John lucas
Tool rest does t have anything to do with vibration. That a function of sharp tools no pressure on the bevel and reduced pressure between the drive and live center
Vertically Challenged?
I used to be 5-10. I'm now 5-7.5.
To keep my tool and the rest it rides on, at a comfortable height, I built a 4" platform around 2 sides of my lathe. Makes a world of difference. 2x4s and some 3/4(not quite) ply and you're good to go, especially if you planning to spend lots of hours spinning wood.
Re: answers
I do have alot to learn. I'm sure it has alot to do with my technique but something about a wooden rest gives me less vibration.---Jack
Re: Vertically Challenged?
Ten years ago I was 5'6".Had been that tall since I became adult. Somewhere in the last ten years I lost 2 inches.Maybe I'm sinking into the ground.---Jack
You Ain't
the Wicked Witch of the East.
Build yourself a raised platform, call it a "dais" if you must, and be comfortable as you work.
Just be careful around children with buckets of water :D
Hence the advantage of a lathe that.....
JamieDonaldson
...has legs that can be adjusted for height. Many lathes have cast legs that are too tall for those users that are vertically challenged. >(
Heard That
Can't raise the bridge, lower the truck!
