Protection when spraying finishes
Fred Holder
I received this question from one of my subscribers and cannot give a good reply, because I don't use spray on finishes. Can you guys help?
"As you did such a good job on my last question and solved my problem, I have
another.
"I am finding that I do need a spray booth for some of my turnings. I really
like the lacquer finishes on lighter woods and so I have the issue of
possible noxious, toxic or explosive volatiles. I am sure other
woodturners have the same problem. I do plan on using the spray booth in
the winter in Montana so I cannot just do it outside. Do you or others have
a recommendation as to whether I should have an explosive proof exhaust fan?
"If so, can you recommend a model and make for such use. I notice that most
fans are in the $600.00 range. That is pricey.
"Thanks for your help and I have really enjoyed your publication.
"Rich"
Re: Protection when spraying finishes
Greg Haugen
Fred,
The first thing that comes to mind for me is, what's the finish? If they can get into an acrylic finish, the risks and hazards are substantially less.
I'd suggest contacting Chris Pytlik or Don Derry. They are the two guys that I go to with questions about spraying anything. They are the two turners that I know that do the most spraying. Maybe an email to them may get the information and response they're looking for.
Dick Coers
You would need the absolutely perfect conditions in a home spray booth to ever have a problem. Combustion needs the perfect air to fuel mixture, then a spark. I've never seen a fan spark. If you were concerned, use a fan with a separate motor. The belt runs out of the air stream, and lets the motor locate outside of the air stream. Explosion proof fans also need explosion proof conduit and switches, or switches a distance from the air flow. Explosion proof doesn't mean sealed tight, it means that it could contain an explosion inside the system and keep it from spreading outside this contained system. I designed explosion proof wiring systems for natural gas compressors in a past job. I've sprayed nitrocellulose lacquer directly in from of a box fan, no issue, but I wouldn't do that in front of my insurance guy.
Re: Fans use induction motors
Doc Green
Every fan that I've ever seen for residential use used an induction motor, the type motor that has no brushes. Without brushes, there is no sparking inside the motor and therefore nothing going on inside the motor that could set off an explosion.
The one exception is the induction motors that use a centrifugal switch to switch out one set of windings (or a capacitor) after the motor comes up to speed. A small spark will be produced when the switch opens. However, I've never seen such a motor used for a small, portable fan.
I would not hesitate to use a box-type window fan from a big box store. No such fan will have a centrifugal switch, and it will therefore be perfectly safe.
~Doc
Doug Turner
Fred, Here is a link to a small airbrush spray booth on sale for $132. This can be vented outside with a common 4" duct fairly easy (even in winter). Lacquers, oil based paints and varnishes (solvent based) should be vented outside.
http://www.chicagoairbrushsupply.com/nepaaisphb.html
bill Crommett
My spray booth is just a whole house 30 in. belt driven fan in the corner of the shop. No sides, no top or bottom. Just a lot of wind going out .
Bernie Weishapl
I bought one from Chicago Airbrush Supply. It is the Paasche Model: HSSB-22-16 Spray Booth and runs $249. It has a working Dim: 22" wide x 20" deep x 16" high. I have it filtered to the outside thru a 4" dryer vent. Works well. I spray lacquar, poly and water based finishes. I change the fileters about every 6 months or so depending on how much I spray. I sit a lazy susan inside, turn and spray away.
Peter Hyde
Maybe the owners/users of the Paasche spray booth should read the instructions as posted on the Chicago Air Brush Supply site. It clearly states "NOT INTENDED FOR USE WITH HAZARDOUS MATERIALS, FLAMMABLE OR EXPLOSIVE PAINTS OR MATERIALS"
What's left?
Dick Coers
If the manual reads, "NOT INTENDED FOR USE WITH HAZARDOUS MATERIALS, FLAMMABLE OR EXPLOSIVE PAINTS OR MATERIALS", what's left? Water based finishes may not smell, but they are not considered healthy. Sure you can spray anything but water in this thing?
